Well I snapped an axle
BF Goodrich KDW's + 4.08 gears + $hitty road + stupidity = snapped axle
Well to make a long story short...I was going to do a little burn out on this back road with my friend and as soon as I dropped the clutch *POP* and there I sat
I had just installed the 4.08 gears over Christmas so I just knew I blew the rear-end. But after inspection and noticing that the right rear axle was turning when the left axle was not, I knew that it broke an axle.
Here is a pic of the outer boot taken apart:
But my question is..Why did it break? Was it because of meaty tires, lower gears and a horrible road? Just because the car has 107,000 miles on it? Or just because I'm dumb and it needed to break to teach me a lesson?
I had just installed the 4.08 gears over Christmas so I just knew I blew the rear-end. But after inspection and noticing that the right rear axle was turning when the left axle was not, I knew that it broke an axle. Here is a pic of the outer boot taken apart:
Never dump the clutch, unless you just went thru water.
I snapped an axle on the street of all places as well, on a 1-2 shift spinning I hit a "bump" in the road and it sheared much like yours. Spinning + suspension compressing and decompressing rapidly = ouch
You have to always be careful of spinning over bumps. Lesson learned, you can get OEM replacements cheap, I got some on carparts.com
I would buy a new cage for the bearings and the part that pushes on the axle inside the cage as well. I snapped and axle, put a new one in only to have the inner bearing assembly break apart on the track two days later. It rounded off the splines on the new axle
or at the very least make sure you take a good look over everything to be sure it dosent have hair line cracks.
I have DSS 5's now, I got them at a KILLER deal brand new I couldnt pass up. First trip to the track the freaking cotter pin somehow fails and I had to replace the Dss 5's with a stocker to get home from the track lol. The stocker I did break on the street though of all places.
Its cheaper to buy many stockers as extra
Yeah it was one of those little quirks that will set you back and aggrevate the $hit out of you. Even worse were all the peeps asking Q's trying to converse with me as Im under the car using my other cars headlights for light and its cold lol. The axle shop spot welded that beotch on and its been fine since.
Workshop12
Mar 23, 2020 01:45 PM
