Does it prolong the life of the clutch if....
Old May 12, 2011 | 09:44 AM
Spider Monkey's Avatar
Spider Monkey
Originally Posted by SSNOS
Why would you guys stay in gear at a light?
Because it is the law?
(I don't do it either though)
Old May 12, 2011 | 11:23 AM
spacecoupe2007's Avatar
spacecoupe2007
And theres that coool factor at a red light where the car starts rolling back
Alsooo if youre worried about it being illegal , at worst, you can just use the ebrake
But personally , neutral works for meee.
Old May 12, 2011 | 11:38 AM
SenHR's Avatar
SenHR
I was taught to go into neutral at lights oh well.
Old May 12, 2011 | 01:19 PM
FenixL1P's Avatar
FenixL1P
i'm currently @ 109k miles (80% highway miles) on stock oem clutch with about 5k miles to go i think... knock on wood. It will last if you keep it in neutral so that you are not slipping... that and limited drag racing... i've "burned" my clutch a few times too....
Old May 12, 2011 | 01:31 PM
drivessidewayz's Avatar
drivessidewayz
You don't really need to push in the clutch to go to neutral, but there's no good reason not to. If you want to prolong the life of your clutch, t/o bearing, and your leg:
double clutch downshifts
leave it in neutral at lights
release it as quickly as comfortably possible during every shift (or just drop it if you don't mind the extra strain on everything else).
The clutch wears whenever it slips, so the less you let it slip the less it will wear. Simple logic.
Old May 12, 2011 | 06:31 PM
SSNOS's Avatar
SSNOS
Originally Posted by So SexZ
Thanks for the answers guys.
I'm a little skeptical towards SSNOS's suggestion of pushing the clutch in only half way though, I'm pretty sure that wears the clutch out faster, I'm guessing he was being sarcastic because I'm a noob.
Anyway, my conclusion: Clutch only wears when shifting into gear but not out of it (thanks pcressy). And skipping gears actually will prolong the life of the clutch (thanks terrasmak and Kcee91).
100% sarcasm. Never do that, makes the clutch slip and wear like crazy. I only clearified this because you seem sincere.
Old May 16, 2011 | 02:18 PM
kingkai's Avatar
kingkai
Originally Posted by Spider Monkey
Being in neutral while you are stopped is illegal bro. Course the logic to why that is so, is flawed thanks to the automatic transmission, but it is still illegal none the less.
I generally take my car out of gear as I coast to a stop, then leave it out of gear and wait till the light changes then shift and start moving. I see no reason at all.. including this "law" to sit with car in gear and clutch depressed at every stoplight. Never heard of this being illegal, I think that people just have bad information and a misunderstanding of how a car works and maybe that started because some believe you should use the engine to slow you down.
Edit: Possibly, it refers to neutral + Ebrake which would be a problem as an Ebrake wont stop you if rear ended while braking will.
Old May 16, 2011 | 07:32 PM
doshoru's Avatar
doshoru
This gets my vote.
The clutch does slip/wear when you disengage. If you disengage quickly, it'll slip less.
I always have it in neutral at lights. I've heard that it's illegal to coast down a hill in neutral (I do it anyways, sometimes....although coasting in gear at low rpms uses even less gas), but never that it's illegal when stopped...I don't see how that's even remotely feasible. If I was standing on the clutch at lights, I imagine my TOB would wear out 1000% more quickly?
Also, skipping shifts can actually wear the clutch more if you upshift quickly...think about it -- the change in rpms when upshifting from 2 to 4 is greater than when upshifting from 2 to 3.
Explanation:
As soon as you push in the clutch to upshift, rpms start to naturally drop. If you time it perfectly so that you let the clutch back out at the exact engine rpm that the transmission would be running at in that gear, then you won't wear the clutch (much).
However...if the rpms have either not dropped enough, OR have dropped *too much*, the clutch is going to be used/worn to "force" the engine speed to match the speed that the transmission is moving at in the next gear.
In the grand scheme of things, skipping a gear on a casual UPSHIFT really isn't going to have any *noticeable* effect on longevity. Skipping gears on DOWNSHIFTS will cause accelerated wear of both the clutch and the synchros. This can be mitigated by single-clutch rev-matching (save clutch wear), and double-clutch rev-matching (saves both clutch & synchro wear). More info on single vs double clutching: http://www.epinions.com/auto-review-...3A351631-prod4
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
