P0011 & P0021 Please Help!
Old Jul 28, 2011 | 08:18 AM
jimman's Avatar
jimman
Exclamation P0011 & P0021 Please Help!
I've been getting an intermitent CEL with P0011 & P0021,
Rough Idle - RPM's drop when clutch is pushed in and will stall at times-vehicle vibrates, engine also rattles.
borrowed a consult and ran some test and at 2k rpm both intake valve timing control solenoids have 0 duty cycle.
pulled drivers side solenoid put 12v to it and it operates fine.
Any thoughts on what is going on
I appreciate any thoughts on this mind boggling issue.
thank you!!!!
2004 G35 6spd
Mods are
Vortech sc
Built Motor
aem fi/c piggyback computer.
Old Jul 28, 2011 | 09:51 AM
Vivid Racing's Avatar
Vivid Racing
Vivid Racing
P0011 is: Intake Cam Position Timing Over Advanced - Bank 1
Possible Causes:
Incorrect camshaft timing
VCT solenoid valve stuck open or continuous oil flow to piston chamber
Camshaft advance mechanism binding, or faulty VCT unit
P0012 is: Variable Camshaft Timing Over Retarded - Bank 1
Possible Causes:
Did you check the wiring at the VCT solenoids?
doc_sus
Sep 5, 2015 11:58 AM
jdee777
Jul 1, 2014 09:20 PM
Currin
Mar 12, 2010 01:52 PM
