PMAS maf
Old Aug 22, 2011 | 02:12 PM
05SickSer's Avatar
05SickSer
Default PMAS maf
Got a few questions about the PMAS maf. Are the sensors a direct swap with the stock DE maf sensor to fit into the housing? I searched a bit but did not find much about it. Or is it something different when using one. From the pictures I have seen the maf looks different then the stock ones so I assume you just swap the stock maf sensor into the housing?
I know with my experience with alti/maximas that the 02-04 could use the LRMAF and the sensor was a direct swap for the 3.5" housing on them. But in 05-06 they changed the maf sensors to the ones that the G/Z have used since 03. And the part numbers are the same and have been confirmed that they work with no issues at all with the ECU.
Yes i realize i will need to tune it after a bigger maf so you dont need to tell me that. This is the one right? http://www.atomicperformance.com/bro...MAF-Meter.html
Thanks
Old Aug 23, 2011 | 04:37 AM
djamps's Avatar
djamps
It's a direct swap. And as you already know, the car is barely going to run without a full re-tune.
Old Aug 23, 2011 | 02:40 PM
05SickSer's Avatar
05SickSer
Thanks I was figuring it was a direct swap, just wanted confirmation
etkms
Jun 19, 2022 06:30 PM
liqalu04
Jan 2, 2022 12:58 PM
350Z_Al
Oct 29, 2020 07:44 PM
