Adjusted my clutch, quick question.
Old Aug 25, 2011 | 07:39 PM
LeviEubanks's Avatar
LeviEubanks
Default Adjusted my clutch, quick question.
I was browsing the web earlier today and found out I can adjust my clutch pedal's position to make the clutch pedal travel shorter. My clutch pedal used to sit about 3/4 of an inch higher than my brake pedal. Now, it sits about a 1/4 of an inch lower than my brake pedal. The engagement point of the clutch is about 1/4 of an inch to 1/2 an inch off of the floor. When I let the clutch pedal all the way out, I can hear the notorious "rattle" that our dual mass flywheels make. However, when I push the clutch pedal all the way in the sound stops about a second after the pedal hits the floor. It almost just sounds like the flywheel/clutch assembly spinning off it's momentum before it stops. Either way, I'm wondering if I've adjusted my clutch pedal too low, or if that's normal. Let me know if you have any useful information. Thanks!
Old Aug 25, 2011 | 10:40 PM
winchman's Avatar
winchman
That's a pretty low engagement point. Anyone unfamiliar with the car would probably stall it from a start or grind the gears when shifting.
Old Aug 25, 2011 | 10:51 PM
LeviEubanks
I went and took it for a drive shortly after making the adjustment, and I can back out of my driveway, drive around town, and pull back into my garage just fine. I haven't stalled it, and I don't think the gears are grinding. It still shifts smooth. No grinding noises or trouble getting it in to gear. I may adjust it up just a little bit more so the engagement point isn't so low. Perhaps to where the engagement point is 3/4 of an inch off the floor. I'm just worried that having it too low would make the clutch not fully disengage when the pedal is pushed all the way down, you know?
Old Aug 25, 2011 | 11:29 PM
hellsoldiers08's Avatar
hellsoldiers08
what i did to mine and my friends clutch is make it same height as the break pedal. i been driving around for like idk 10,000 miles plus easily and no problems so far. hope this helps .
Old Aug 25, 2011 | 11:39 PM
LeviEubanks
I tried that when I was adjusting it, but it still felt a little too high for my taste. So, I put it about 1/4 to a 1/2 an inch lower than my brake peddle. I might adjust it back, we'll see.
Old Aug 26, 2011 | 08:42 AM
hellsoldiers08
ya, i know what you mean but hey it better than stock and your playing it safe but hey it your car :0)
Old Aug 26, 2011 | 09:06 AM
Duckeee's Avatar
Duckeee
i adjusted mine a few months back but for some reason I feel like it went back to the way it was LOL
tightened everything up so i dont know why. going to take it to the dealer to let them have a shot
Old Aug 26, 2011 | 09:58 AM
hellsoldiers08
from what i have read dealer has denied that you can do that adjustment...
Old Aug 26, 2011 | 11:45 AM
LeviEubanks
Well, I had no problem doing it so I don't know what the dealer is talking about. lol It only took me about twenty minutes to do with hand tools in my garage. One of the easiest/best mods I've done so far. Shifting is so smooth now.
Old Aug 26, 2011 | 12:10 PM
winchman's Avatar
winchman
Why would the shifting be smoother? As long as the clutch is being disengaged between gears, the shifts should be the same.
Old Aug 26, 2011 | 12:14 PM
Duckeee's Avatar
Duckeee
im sure he meant that his shifting abilities have improved because of the adjustment, hence smoother shifting.
Old Aug 26, 2011 | 12:50 PM
LeviEubanks
As in the shifting is less jerky. Before when the clutch pedal was at stock height, I had to let it out about 3 inches before it would even begin to engage. Now, it engages a lot faster, making my shifts smoother instead of jerky because of all the extra clutch travel.
Old Aug 26, 2011 | 01:23 PM
Vivid Racing's Avatar
Vivid Racing
Vivid Racing
A friend did this in his BMW and it made heel-toe shifting much easier, according to him. I know what you mean about the jekiness, too. Another friend has an E46 3 series and the clutch travel is insanely long... Neither of us are 100% smooth all the time in his car : /
Old Aug 26, 2011 | 01:59 PM
LeviEubanks
Yeah, it felt like I was driving a big truck before. lol Now it feels like the proper sports car that the 350z is. I'm very happy with it.
Old Aug 26, 2011 | 02:16 PM
mattleegee's Avatar
mattleegee
tool list?
Old Aug 26, 2011 | 02:50 PM
hellsoldiers08
^ search button ;0)
Old Aug 26, 2011 | 03:03 PM
LeviEubanks
All I used was a small wrench that fit the lock nut on the end of the rod and a little bit of elbow grease to turn the rod. lol It's very simple.
Old Aug 26, 2011 | 03:10 PM
hellsoldiers08
but if he wants detail there is a thread about this with detailed pictures and such.
Old Aug 26, 2011 | 03:12 PM
LeviEubanks
True, the search button is your best bet for that :] lol
Old Aug 26, 2011 | 03:22 PM
mattleegee's Avatar
mattleegee
