Engine Chatter/Rattle while turning ignition off
Old Sep 22, 2011 | 06:27 PM
soypinoy101's Avatar
soypinoy101
Default Engine Chatter/Rattle while turning ignition off
I'm sure this has probably been talked about on the forum already but couldn't really find what i needed through the search function. Anyways, i just got a 06 rev up with 60k miles and a week after i got it every time i turn the ignition off there is a rattle when the engine turns off. But the rattle(chatter) is gone when i turn the car off with the clutch engaged. Called the local dealership they said it might be a worn throw-out bearing. I have no clue. Anything helps Thanks
Old Sep 22, 2011 | 10:31 PM
350XTCz's Avatar
350XTCz
Mine 06 has always done this.
Old Sep 23, 2011 | 06:53 AM
djamps's Avatar
djamps
It's normal clutch chatter. If it made the sound with the clutch pedal depressed, then you would have an issue.
Old Sep 23, 2011 | 11:16 AM
ridered929rr's Avatar
ridered929rr
Throw out bearing....does the same thing when running as well, right?...If you are at a stop light put the car in neutral and let the clutch out, you will hear a spinning sound, push the clutch in and it goes away. Mine has been doing this for 75K miles no issues other than the sound
Old Sep 23, 2011 | 01:08 PM
soypinoy101
thanks for the imput folks. my buddy is a nissan tech he said that it is common with the car and isnt a problem.
liqalu04
Jan 2, 2022 12:58 PM
3vilbunny
Jul 18, 2017 05:10 PM
Fixxxercask
Nov 9, 2015 11:10 AM
