570z
Old Sep 26, 2011 | 10:21 AM
NZMOWND's Avatar
NZMOWND
what are the specs on those vsxx's?!?!
Old Sep 26, 2011 | 10:33 AM
jerseystyle's Avatar
jerseystyle
Nice. In for more pics and times!
Old Sep 26, 2011 | 10:41 AM
Czarrr's Avatar
Czarrr
Originally Posted by d1mon3k
lol I gotta look good on the streets man, I'll go to the track with slicks and much lighter rims. Otherwise, it'd be pointless
Hahaha. Baller status.
OT. Build looks great.
If you don't mind me asking...
Could you continue to post pics and add prices of this process?
I ask so you can help noobs like myself.
So we can get a ball park estimate of how much something like this cost.
Old Sep 26, 2011 | 10:58 AM
d1mon3k's Avatar
d1mon3k
19 x 9.5f and 19 x 11r
I wanna say the offsets for around +10 to +15. The guy I bought them from took the damn stickers off the barrels that had all the stats. I'll be rolling the fenders for sure when I get the right suspension set-up
Old Sep 26, 2011 | 11:04 AM
d1mon3k's Avatar
d1mon3k
I'll post it up when I get a list together, stay tuned for that
Old Sep 26, 2011 | 01:13 PM
xelaxor's Avatar
xelaxor
Battery inside the car = bad idea. Just a FYI. I can't find any info on that battery but if's a lead acid battery then you need to remove it.
Old Sep 26, 2011 | 01:16 PM
SQBassHead's Avatar
SQBassHead
nice!!!
so was this the first time your shop did this to a z?
was it pretty straight forward with the sikky kit?
does everything else in the z work just like stock?
Old Sep 26, 2011 | 03:00 PM
Quamen's Avatar
Quamen
Originally Posted by djamps
Hmm, I never got questioned on my FPR it's in the same spot. And the tracks i go to are pretty damn picky. I've seen some people mount them off to the side which I would consider far more dangerous being closer to the manifolds should a leak develop.
I guess it depends on the governing association. The idea is that in the case of a flexplate, flywheel, clutch or torque converter explosion, they don't want your fuel system near the flying parts. I believe the NHRA is 6" fore or aft the bellhousing hence why most people mount them on the side. I had mine in the same spot as yours last year and decided to relocate it.
Old Sep 26, 2011 | 04:31 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
I have my old drag tires mounted on steelies (a pair of ET Streets 15x10.5 that still have plenty of tread left), if you're interested in a cheap set.
Yes, that red car was totalled by an old lady last year, so I got this one for like 11k. I'm prolly going to an 1/8 mile track to practice this Saturday, I'll let you know which one when I find out.
Why go to a 1/8 mile? That's pointless and a waste of time. Go to either TX Motorplex at Ennis or Dallas Raceway at Crandall. I recommend the latter, as it's a faster track and usually has better prep.
Also, if this is going to be a drag car, then you don't really need bigger brakes, especially not in the rear, so I'd only replace the fronts if anything.
Old Sep 26, 2011 | 09:17 PM
ImWeeZzel's Avatar
ImWeeZzel
Originally Posted by ImWeeZzel
in for more pics aswell
Originally Posted by 06blueZ
amazing, its like you two are twins...
there can only be one...
Old Sep 27, 2011 | 11:18 AM
bbs350z's Avatar
bbs350z
where have you been hiding lol? btw did you read up on the ls sections and do the drill mod for your sikky lines??
ps i iz jealous yours runs and mine still doesnt lol
Old Sep 27, 2011 | 02:42 PM
d1mon3k's Avatar
d1mon3k
Thanks for the advice on the brakes. That'll help alot. PMing you for more info on you're tires.
Old Sep 27, 2011 | 02:44 PM
d1mon3k's Avatar
d1mon3k
haha, don't worry my shop did the install, and they had a lot to work through. I'm not a DIY'er on that big of a project.
Old Sep 27, 2011 | 03:02 PM
3hree5ive0ero
Retired Admin
You really should've come out to the drag strips with me when I still lived there. I drag raced all alone for like 5 years in the Z! PM'd you back.
BTW, about the brakes, don't replace them if you don't need to. All you're doing is slowing yourself down in a straight line and you have plenty of space to do that after the 1320'.
Old Sep 27, 2011 | 03:06 PM
Itzcashew's Avatar
Itzcashew
Originally Posted by Flo-ridaZ33
Not really but they're definitely not for drag though. Most multi piece wheels are heavier then a mono wheel. I can pick up my TE's with one hand while my LM's and VSXX's require a little more effort.
Truth. My 3 piece advans requires a double hand ****** and clean. While my friend's TE was like a dumbell curl.
Old Sep 27, 2011 | 03:10 PM
3hree5ive0ero
Retired Admin
^ Work out more?
Old Sep 27, 2011 | 03:39 PM
Flo-ridaZ33's Avatar
Flo-ridaZ33
^TE's are just that light.
Old Sep 27, 2011 | 03:46 PM
  #38
Spork's Avatar
Spork
A "drag car" with "hellaflush" offsets and a stretch?
Scrap those wheels/tires for something proper/wide.
Old Sep 27, 2011 | 03:50 PM
  #39
3hree5ive0ero
Retired Admin
^ He's going to have separate wheels for drag strip use, like most drag racers. Plus, width and offset doesn't matter nearly as much as the compound of the tires, proper suspension, and alignment.
Old Sep 27, 2011 | 03:55 PM
  #40
jerseystyle
Work on reaction time/launch?
When I was stationed at FT Campbell, 1/8th was all we had.
