Developing a FAQ page for Drivetrain
Old Jan 9, 2004 | 07:38 PM
12SecZ's Avatar
12SecZ
I can only base the DS loop on my 12 sec FBOD's.
They both had DS Safety Loops.
It's a good and cheap mod and protects your drive line.
They go for about 100 bucks and some even are bolt ons so why not have one? I guess it's a 1/4 mile thing and track specific, some tracks don't tech at all and this can come back to haunt you when a car goes into the wall and everyone moans like ughhh while instead of staging to run you wait an hour for clean up.
Old Jan 9, 2004 | 10:24 PM
D'oh's Avatar
D'oh
Originally posted by 12SecZ
Q?
Why hasn't anyone addressed the NHRA required DS Safety Loop and do they even make one?
The initial answer is that they are not required since we sit in front of the diff.
They may be recommended, and if enough people start draggin the Z, then it is more likely for someone to make one. Therefore my second answer is that there is not enough of a market for one at this time (for the Z).
Finally, since the Z's driveshaft is plastic/CF, it is designed to shatter in a crash, which might eliminate the need for the safety loop since there would be nothing left to constrain.
Anyway, I don't know enough to say for sure why there isn't one available, or even if they are useful in the Z, but those could be some potential reasons.
Maybe that bluefish dude would have an idea if anything has been made for the Z.
-D'oh!
Old Jan 11, 2004 | 07:30 AM
350Zzzz's Avatar
350Zzzz
Professional
Default Q
What causes the clutch not to disengage completely, even with padel full up position, on a 6MT?
Old Jan 11, 2004 | 08:09 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
A DS lop is scertainly required at some oint on all cars, be they FWD or RWD.
Here are the NHRA Sort Compact Rules:
http://www.nhrasportcompact.com/2003/rules/GenReg.pdf
It's actually quite easy to do, and if the inerest is there, we can easily have them done for you guys who drag..I cna just build off my own car.
Old Jan 11, 2004 | 09:17 AM
12SecZ's Avatar
12SecZ
I'm interested in a direct bolt on that doesn't rattle.
I know you are supposed to drop the shaft and go through it but let me see what you come up with our track checks for them and gets stricter on Tech In every year.
thanks Adam
Old Jan 12, 2004 | 04:23 AM
12SecZ's Avatar
12SecZ
Next One,
What is the gear ratio of a Touring A5T?
Old Jan 12, 2004 | 05:16 AM
Z1 Performance
Former Sponsor
I posted that one before someplace....IIRC around 3.38's
Old Feb 10, 2004 | 07:33 AM
G35_AutoX's Avatar
G35_AutoX
Originally posted by andypandy
are 350z and g35 drivetrain parts interchangable?
ie: 350z nismo clutch assy installed into a g35c 6 speed.
Here are some differences that I've noted.
Driveshaft is different: G35 has a 2 piece shaft since it's longer while the 350 has a 1 piece.
Diff assemblies are the same, keeping in mind that by that I mean the LSD equipped 350 diff is the same as the LSD equipped G35 with one exception confirmed: the G35 5ATs have a different ring & Pinion gear. This may be true on the 5AT coupe as well, but I haven't received confirmation from anyone on this. I also don't know if this holds true for 5AT 350's or not, but if anyone knows, please confirm.
Old Feb 10, 2004 | 08:38 AM
Z1 Performance
Former Sponsor
interesting - whats final drive on the G manual's then?
Old Feb 10, 2004 | 12:55 PM
G35_AutoX's Avatar
G35_AutoX
I believe the MT gears are 3.54:1 and the AT gears are 3.36:1
Old Feb 24, 2004 | 05:03 AM
PoWeRtRiP's Avatar
PoWeRtRiP
my contribution:
jwt flywheel/clutch are compatible with your stock throwout bearing and pilot bearings. these run 40 for the throwout and 8 for the pilot so you might as well replace them while your doing a flywheel job.
Old Feb 26, 2004 | 03:24 AM
PoWeRtRiP's Avatar
PoWeRtRiP
*edit* the jwt clutch kit does include the throwout bearing and pilot bearing
Old Feb 27, 2004 | 05:52 AM
Daniel G's Avatar
Daniel G
Would you have the need for a DS safetly loop? Being that the driveshaft is made out of CF? I ask this because I had a 'ACPT' Carbon Fiber drive shaft on my F-Bod.....it broke and just disintegrated. By the way my 'ACPT' drive shaft broke where the shaft meets the metal neck...not becuase I had too Much HP, but because ACPT is a piece of S@#t. I'm still fighting to get a replacement or money back...or at least a discount. @#$@# $700 DS.
Also, does the G35 have a CB driveshaft? I haven't got around to looking under there yet.
Old Apr 19, 2004 | 12:56 AM
nitrous350's Avatar
nitrous350
hey guys
my 350z ran 12.56 on 1320 feet
12.56 came out from my g-tec
hey guys check out this my 350z has a problem with Level 10
so i just dismantle on my AT trans. whene i look on my car
they have some cross bar right after trans its looks like DS Roof
is that cross bar will ok with NHRA???
and now i look for 5 Point Roll bar on my car
is any one know some one make bolt on type ?????
Old Apr 20, 2004 | 11:18 AM
zturtle's Avatar
zturtle
Stock rear ends are rated to the S-Tune spec of 305hp at the crank. Nismo diffs are nice if you are stepping up.
Old Apr 20, 2004 | 12:59 PM
12SecZ's Avatar
12SecZ
Quick answer to your NHRA regulation question is no, it wouldn't meet their guidelines. It has to go *around* the drive shaft in a loop.
Good news is that no one is checking much for this where I have went. Not once actually. Bust a 11 though and they may send you to be seriuosly teched ha-ha!
Old May 4, 2004 | 07:29 AM
PoWeRtRiP's Avatar
PoWeRtRiP
can someone explain cvtcs system to me, mostly when does it begin adjusting timing? how do you adjust it, can it be done manually or does it take a reflash? and can it be deactivated if i get a tt kit?
Old May 10, 2004 | 12:30 PM
  #38
jreiter's Avatar
jreiter
Default stock clutch - maximum power
What is the maximum power handling of the stock Z clutch?
I often see people saying you should upgrade your clutch when swapping out the flywheel, but I don't see why that is necessary if you don't plan on making big power upgrades such as forced induction. Sure, it will save you labor costs if you do them both simultaneously, but why spend the extra hundreds of dollars on a higher power clutch if you don't really need it?
Old Sep 19, 2004 | 03:18 PM
  #39
Tien's Avatar
Tien
Q: 1)what is LSD ?
2) what does it do?
3) do most of the car have it? or mostly performence car?
4) if the car doesn't have LSD, can i put one in?
5) is it nessasary ? (plz forgive my spelling...)
thank you
Old Sep 19, 2004 | 09:56 PM
  #40
Tien's Avatar
Tien
eerrr.. nevermind guys ^^
i just read some LSD article.. and it answered all my weird questions.. =P
