noob shifting
Old Nov 27, 2011 | 05:09 PM
tinman05's Avatar
tinman05
Default noob shifting
So its been a long time since I have driven a stick and I was wondering if there is a good shift point for speed shifting (ie. shifting without using the clutch) in the 2007 350z.
Old Nov 27, 2011 | 07:04 PM
Spork's Avatar
Spork
Max rpms br0
Old Nov 27, 2011 | 07:06 PM
DB350's Avatar
DB350
whatever car you "speed shifted" before this one, just shift at the same point. all cars are created equally in regards to a proper "speed shift"
Old Nov 27, 2011 | 07:10 PM
Kcee91's Avatar
Kcee91
Just use the clutch, why would Nissan put in a clutch if we didn't need it? Unless you want a new transmission, go for it, but imho I wouldn't recommend it.
Old Nov 27, 2011 | 07:11 PM
DB350's Avatar
DB350
sshhh
Old Nov 27, 2011 | 07:12 PM
faiz23's Avatar
faiz23
FEZZZZZZ
Old Nov 27, 2011 | 07:21 PM
DB350's Avatar
DB350
should be
y no double clutching?
because granny shifting
Old Nov 27, 2011 | 10:56 PM
qmoney06's Avatar
qmoney06
You're obviously a noob if you want to drive 6mt and not use the clutch. Go get a 5at and use the manual override. You can "speed shift" all day.
Old Nov 27, 2011 | 11:39 PM
Shift just before you hit the juice of course.
Old Nov 28, 2011 | 12:00 AM
BTW you have 6 months to show your speed shifting skills here
https://my350z.com/forum/drag/233840...ons-stock.html
or face serious ridicule for speed racer wannabe nonsense.
Old Nov 28, 2011 | 12:07 AM
hugo350z's Avatar
hugo350z
before you speed shift all 350z's require a new torque converter, the stock slips when engaing at high rpms, therefore preventing you from speed shifting. Get a new torque converter in your z, youll be good. Also make sure you get the one for the manual transmission, common mistake. If you cant afford it just pull out the converter fuse(15amp) i believe, and youll be good for now(pulling the fuse disables it). Dont let the guys on here get you, some will give you wrong info on purpose and act like douches. Anyways good luck dude, welcome to the forum
Old Nov 28, 2011 | 02:59 AM
terrasmak's Avatar
Unless you feel like replacing the trans, just use the clutch. Also speed/slam shifting with the clutch a Z will require you to replace the trans faster than needed.
Old Nov 28, 2011 | 04:58 PM
Bottled Water's Avatar
Bottled Water
Theres a clutch in this car!? Dang...
Old Nov 28, 2011 | 06:14 PM
Cass007's Avatar
Cass007
Old Nov 29, 2011 | 05:52 AM
natedogg713's Avatar
natedogg713
shifting without the clutch should be used in emergency situations only! (such as the deadpedal coming off and gettign lodged under the clutch, true story) or unless your a trucker in a company truck with a very heavy clutch. its good to know bad to use. listen to everyone else clutch is there for a reason.
Old Nov 29, 2011 | 09:49 AM
bmccann101's Avatar
bmccann101
Originally Posted by Cass007
Sark says GTFO for the win.
Nice.
btw....
is this OP actually Brian Spilner.. ?
Did you " almost had me" OP ?
Dont choo know that teh speed shifts causes teh car to blow up from too much nitrous tanks in teh seatz?
Old Nov 29, 2011 | 10:32 AM
tonyzS/C03's Avatar
tonyzS/C03
oh god... what has happened here? looks kinda like a **** sandwhich that everyone has added their little bit too
Old Nov 29, 2011 | 10:50 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Why on earth would you want to rape shift a vehicle with synchros?
Even when RACING I have always used the clutch. Although youtube experts think I dont lol
Old Nov 29, 2011 | 02:01 PM
tinman05's Avatar
tinman05
wow flame fest as expected. the reason I ask had nothing to do with racing. I just hear about it being done in my dads malbu that had a 3 on the floor. he clamed he never used his clutch during daily driving. I had never heard of it....so I thought I'd ask.
Old Nov 29, 2011 | 04:07 PM
saywat?'s Avatar
saywat?
^like father like son
