Knock Sensor
Old Dec 26, 2003 | 09:31 AM
philsill350z's Avatar
philsill350z
Default Knock Sensor
OK GUYS I GOT THE SUPER AFC INSTALLED YESSS I DID IT! ONE QUESITON MY KNOC SIGNAL SHOULD IT READ ZERO ALL THE TIME OR DO I HAVE THE WRONG WIRE THANX FOR THE HELP GUY
Old Jan 8, 2004 | 08:17 AM
dollar99's Avatar
dollar99
I have the same question, anyone care to answer? How do you read the Knock level ont he S-AFCII?
Old Jan 8, 2004 | 04:10 PM
jesseenglish's Avatar
jesseenglish
John from J&S described the signal to me. Doesn't look like you could use it with the S-AFC
The output from a knock sensor is an audio signal, like from a microphone. If you connect one to a set of amplified headphones, you will hear the engine running, without the exhaust noise.
The sensor on the 350z has a low output level. You might get a volt or so peak to peak with heavy knock. The frequency varies from 5kHz to 10kHz, depending on the cylinder bore diameter.
Old Jan 8, 2004 | 10:26 PM
elektrik_juggernaut's Avatar
elektrik_juggernaut
Default Re: Knock Sensor
you probably have the wrong wire......several wires have the same color coding......verify the pin number is correct on the harness........white wire, pin 15
Old Jan 9, 2004 | 05:10 AM
Tfasano's Avatar
Tfasano
Default Re: Re: Knock Sensor
Were you able to tune the SAFCII? I was told you need a wideband 02 sensor, which is big bucks to properly tune the A/F ratio. What did you do?
Old Jan 9, 2004 | 01:05 PM
philsill350z
i havent tuned mine yet im not done with my mods but im taking it to a place to have it tuned
liqalu04
Jan 2, 2022 12:58 PM
2ndchanceZ
Oct 26, 2015 08:03 PM
350Z Project X
Oct 17, 2015 05:16 PM
