Help with Fuel injectors
Old Feb 22, 2012 | 01:20 PM
trose1006's Avatar
trose1006
Default Help with Fuel injectors
I am looking to upgrade my fuel injectors and fuel rail. Just wondering what pointers people have out there. what size is the best and will i need to get it tuned after? anything you can help me with will help a lot. thanks
Old Feb 22, 2012 | 01:29 PM
rookie_z's Avatar
rookie_z
did you search the forums first? there are many about mods and what you can do without tuning and what you need tuned
Old Feb 22, 2012 | 01:39 PM
jerseystyle's Avatar
jerseystyle
First pointer: SEARCH!
Second pointer: POST IN PROPER FORUM!
Old Feb 24, 2012 | 08:55 AM
Chris@DW's Avatar
Chris@DW
You'll need to know certain spec/goals about your build.
We have a fuel calculator on our site that can help you determine what size injectors you need > www.deatschwerks.com/fuel-calculators/
If you are doing a gasoline build, I'd recommend using .6 for your BSFC. If you are doing an E85 build, I'd recommend using .8 for your BSFC.
For IDC (injector duty cycle), I'd recommend using 85%. This will give you some head room on the injectors as you can run them up to 92-93% before computer basically holds them static.
If you find yourself between sizes, I'd recommend going with the larger injector.
