OEM Wideband o2 sensor on an 03
Old Feb 26, 2012 | 02:51 PM
DeDicAt3D's Avatar
DeDicAt3D
Default OEM Wideband o2 sensor on an 03
I've searched quite a bit but I'm unsure if I can do the following so I wanted some input from the community.
Is it possible to replace my 03 Z's o2 (rear) narrow band sensors with that of a newer (wideband)Z's o2 sensors?
The reason I'm asking this is because I ordered Osiris and I just found out that I need wideband o2 sensors and I rather not mess with the wiring of the car but if its not possible then I might just have to do it.
Thanks for any input.
Old Feb 14, 2013 | 07:27 PM
j3tt2's Avatar
j3tt2
Wondering the same exact thing lol. I want to do this for tuning purposes. Any insight with be appreciated
Old Feb 15, 2013 | 03:04 AM
bmyles's Avatar
bmyles
You would need to swap out for an ECU that has provisions for a wideband. I suppose it's possible that the '03 ECU has the capability, but I'm almost certain the ECU harness for a wideband connection would be different. Also, widebands are always the primary O2 sensor, not the secondary, since you want your true AFR reading before the cat converter.
Old Feb 15, 2013 | 03:14 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
^this
also nissan only ran 4 wires to each rear sensor. widebands are a minimum of 5.
Old Feb 15, 2013 | 05:22 AM
iideadeyeii's Avatar
iideadeyeii
The controller can put out a simulated narrowband signal(0-1v) to the ecu and you can use the wideband for a gauge/logging as you normally would.
Old Feb 15, 2013 | 05:24 AM
bmyles's Avatar
bmyles
What is this "controller" you speak of?
Old Feb 15, 2013 | 04:06 PM
binder's Avatar
binder
There is no controller that will output the ecu's oem readings.
This is why osiris falls short. You have to purchase everything separate: widebands and boost controller.
Word has it innovate widebands (lc1) can be recorded in the same program as osiris now so at least you can log it with the rest of your stuff unlike when I used to have osiris.
Dr.Paulyy
Jul 29, 2019 07:45 AM
350z_z33.
Jul 3, 2017 04:01 AM
Calinismo350z
Sep 14, 2015 04:04 PM
speedsniper
Sep 14, 2015 08:46 AM
