Engine rebuild or New Engine
Old Mar 4, 2012 | 07:57 PM
CanadianDream's Avatar
CanadianDream
Default Engine rebuild or New Engine
Alright guys, bad weekend but car has started blowing blue smoke - and only 65k miles and well maintained. Mainly after idling so figure rings or valve seals. Just curious the cost of rebuilding the engine versus just swapping a used engine in.
Anyone have an estimate on the cost of doing valve seals? rings?
Taking it to the shop sometime this week so will have a better estimate, just trying to get prepared for how bad it could be.
Thanks.
Old Mar 5, 2012 | 07:47 AM
bbs350z's Avatar
bbs350z
used engine will be much cheaper, assuming you remove and reinstall yourself. just make sure you check out the new motor thoroughly and get the model specific motor (de/revup/hr)
Old Mar 5, 2012 | 07:53 AM
CanadianDream
Thanks, assumed as much. Any trusted sources for used/rebuilt engines? Posted in the forums so will see if anyone has one.
Old Mar 5, 2012 | 10:54 PM
SemperFly's Avatar
SemperFly
If you go to a salvage or something I suggest u ask for a g35 sedan motor only because they seem to charge a **** ton more for a similar condition z motor. Exact same engine, just have to change 2 things(oil pressure sensor by the the oil filter and the little "shim" on the back of the block where it mates to the tranny. Buy 1 and have a mech inspect it for u and save ur receipt.
liqalu04
Jan 2, 2022 12:58 PM
350Z_Al
Oct 29, 2020 07:44 PM
3vilbunny
Jul 18, 2017 05:10 PM
Fixxxercask
Nov 9, 2015 11:10 AM
