Pulley: Tech Writeup and Review (yes again!)
Old Dec 31, 2003 | 01:56 PM
wadd3456's Avatar
wadd3456
Default Pulley: Tech Writeup and Review (yes again!)
Vic asked that I do a quick review of the Pulley install. First Id like to detail the installation so there is no confusion. It’s not as easy as just “putting your foot on the brake and throwing it in gear”. So, here we go……..
1st-- Jack up the car and remove the under pan (plastic) with a 10mm ratchet or air-gun.
2nd -- Do NOT loosen the belts yet. Get a breaker bar or ratchet with a 2-3foot pipe ready instead. Go pull the e-brake and throw it in 6th gear. Not 1st, not reverse….6th.
3rd- Have a friend slam the brake or do what I did and throw a 2x4 between the seat and pedal.
4th – Flip your hood open and chock it fully extended with something. Why do this you ask? Because no one wants to have the hood slam on their heads when the nut breaks loose. Trust me, it can happen! Not to me, but it has happened.
6th -- Remove the plastic shroud over the intake manifold for clearance.
5th -- Now place the breaker bar on the crank pulley nut with a deep drive ¾ (if you have no metric) and turn toward the passenger side. You will be standing OVER the vehicle while doing this….not under it. The pulley may spring a little but it will crack loose.
6th – Loosen the nut on each idler pulley (shown below) using a 14mm.
7th – Loosen the bolt till the tension is off the belts (shown below) using a 12mm.
8th – Remove the belts.
9th – Ram a large flat head screw driver behind the pulley at the top. Then ram another one from under the car behind the pulley on the bottom. Keep tapping with a hammer till it pops loose.
10th – Reinstall the new pulley over the key and tap gently on it with a hammer. Reinstall the nut and torque down to spec (can’t recall what that is).
11th – Reinstall the new belts.
Most of you know how to do this and are probobly saying "duh!" but this write up isnt for you I’ve installed pulleys in the past but NONE have given me this much trouble when trying to remove the bolt. But, the reward was worth it.
The vehicle has more response off the line due to less rotational mass. It almost feels like there is less effort to get you going. For those of you that don’t quite understand the physics of it, think of it this way. Tie a string to a rock, spin the rock with 1foot of string out, and then spin it with 3 feet of string out. It’s much more difficult to get it going quickly with 3 feet of string. This principle is the same on the pulley, which has a smaller diameter (i.e., smaller string). For inertia this same idea applies. For a rock that weighs more then another, it’s more difficult to spin a 3lb rock on a string then a 1lb rock. Same applies for pulley weight. I’m sure 90% of you already knew this, but for the 10% of you, I thought this would help.
All in all, it was a good investment and I can validate all your good reviews. Thanks Vic for the pullies.
PS- should I install the others? They seem to be very similar if not same in diameter and I can’t really tell if there would be much difference in mass.
Attached Thumbnails Pulley: Tech Writeup and Review (yes again!)-idlerbolt1.gif
Old Dec 31, 2003 | 01:57 PM
MY350Z.COM's Avatar
no prob, glad you like em.
Victor
Old Dec 31, 2003 | 01:58 PM
wadd3456's Avatar
wadd3456
Other idler bolt to be loosened AFTER the nut on the front is loosened.
Attached Thumbnails Pulley: Tech Writeup and Review (yes again!)-idlerbolt2.gif
Old Dec 31, 2003 | 02:00 PM
wadd3456's Avatar
wadd3456
And the ole nut on the front.
Attached Thumbnails Pulley: Tech Writeup and Review (yes again!)-idler1.gif
Old Dec 31, 2003 | 02:02 PM
MY350Z.COM's Avatar
did the belts fit fine? they weren't the UR speced belts, one was slightly shorter.
Old Dec 31, 2003 | 02:03 PM
wadd3456's Avatar
wadd3456
last picture.
This is the other idler nut on the front.
Attached Thumbnails Pulley: Tech Writeup and Review (yes again!)-idler2.gif
Old Dec 31, 2003 | 02:12 PM
wadd3456's Avatar
wadd3456
Yeah no squeelez or anything. Im not quite sure if I torqued it too much or not.....havent a clue. Anyone know?
Old Dec 31, 2003 | 03:31 PM
zzzya's Avatar
zzzya
No one has answered this question yet for me. Does the 6MT have an access panel to the flywheel on the drivers side? On the 5AT there is an opening to the flywheel that is covered and you have to remove two bolts holding the cover on. When you take off that cover you have access to the flywheel. Then you still a crowbard or large screwdrive in the gears. You can also do this by removing the starter which is also very easy to do. The flywheel will not be harmed as it is very strong. By "jamming" the flywheel you will stop the crank from turning and it is very easy to then remove the pulley. This requires no help, no one standing on the brakes and I use a regular breaker bar with no extension. It makes it really nice to then reinstall the new pulley as well. I did it by myself from under the car with car ramps.
Old Dec 31, 2003 | 04:00 PM
mofoz's Avatar
mofoz
great writeup. we need more credible and knowledgible posts like this!
Old Dec 31, 2003 | 04:06 PM
wadd3456's Avatar
wadd3456
Gracias
Old Dec 31, 2003 | 04:16 PM
vic grant's Avatar
vic grant
great pics, nothing like actually seeing the stuff before you crawl under it.
Old Dec 31, 2003 | 05:24 PM
EnthusiastZ's Avatar
EnthusiastZ
Any vibration problems with that pulley installed?
Old Dec 31, 2003 | 05:37 PM
Daniel G's Avatar
Daniel G
Is the crank pulley bolt re-usable? A lot of cars use crank pulley bolts that are "torque to yield".
Old Dec 31, 2003 | 06:42 PM
2003z's Avatar
2003z
Scott, as for the other pulleys, UR made a post on g35driver saying they were equal in hp addition as the main pulley due to their lower mass, for what its worth.
Old Dec 31, 2003 | 07:01 PM
12SecZ's Avatar
12SecZ
The other two are looks only and have fun with the stock alternator bolts haha! I measured they are exactly the same just lighter. But if you have them, put them on! I couldn't get the stock alt bolts to turn either
Awesome write up!
Old Dec 31, 2003 | 08:30 PM
mofoz's Avatar
mofoz
i think you will see minimal gains from the other 2 pullys from what i have read.
Old Jan 1, 2004 | 04:04 AM
zillinois's Avatar
zillinois
I would add on final thing to the install list.
Check your belt tension after 100 miles or so.
Old Jan 1, 2004 | 05:44 PM
uro279's Avatar
uro279
why check belt tension after 100mi? why would it tend to change v. stock?
thanx
hulkout
Apr 28, 2017 09:00 PM
nanotech
Oct 2, 2015 05:02 AM
derekinthez
South East
Sep 28, 2015 06:35 PM
ILoveDrifting
Sep 7, 2015 03:15 PM
