550cc injectors and 255 pumo enough?
Old Apr 10, 2012 | 04:08 AM
mhammel20's Avatar
mhammel20
Default 550cc injectors and 255 pumo enough?
Hey guys I am wondering if 550cc Injectors and a walbro 255 pump would be enough with a twin Turbo set up on my car running 8-9 pounds. I'm not going to do the TT til next user due to money issues. But I'm going to get injectors pump and tune my car to e85. My motor needs a tune anyways I built it and got it together to where I can run on stock ecu for now. I think I should be fine with 550cc and 255 on motor but will it be enough for twins? Thanks
Old Apr 10, 2012 | 09:03 AM
Kcee91's Avatar
Kcee91
Hey bro, depends on the the power levels you want. Of course if you want to run more boost, you need more fuel hence larger injectors. I'd go with a set of nice 1000cc injectors, but I'm pretty sure you have to run larger injectors for the e85. Quote me if I'm wrong anyone. As for your build you should also invest in a return fuel system. The most important of all is a CONSERVATIVE TUNE! TUNE TUNE TUNE is key for longevity. Good luck.
Old Apr 10, 2012 | 09:22 AM
Ruthless18x's Avatar
Ruthless18x
You're going to run e-85 NA? Sounds like a waste of money.
Why don't you just wait until you can afford the turbos?
Old Apr 11, 2012 | 03:39 PM
mhammel20's Avatar
mhammel20
ya i plan on going wi0th 1000cc injectors and 2 255 pumps when i go TT. but for now im going to go with 550cc injectors 1 255 pump and im going here in the next 3-4 weeks down to Dynosty and getting the car tuned. so i know it will be tuned by the best.
Old Apr 11, 2012 | 05:44 PM
DaveJackson's Avatar
DaveJackson
Master
Sounds like you're mind is made up, so I guess you're all set.
