Blew stock revup
Old May 29, 2012 | 08:01 AM
drivessidewayz's Avatar
drivessidewayz
Default Blew stock revup
So, the intricate details aside...my fan assembly quit working while I was legally operating my Z and the engine overheated to the point that it blew. I have the extended fan warranty as well as the Nissan certified used car warranty which covers me for 84mo/100k from 7/12/06 given a $50 deductible per part or whatever that is. I*just* called AAA and I'll have it at the dealer in two hours or so.
As far as what blew, I don't know. What is known:
*Neither fan will kick on
*Engine did turn over and run in a limited fashion for probably 45 seconds total after the blow, but as of now is seized and will not turn over at all.
*heat gauge was fine 1.5 minutes prior, but was beyond the "H" mark at the time it refused to restart.
*Fuses are fine.
*Oil level is fine; no metal shavings.
*When it did turn over, it made a god-awful scraping noise.
*Transmission is fine.
*Coolant, while low from boiling over, is not leaking.
*No leaks of any kind.
edit: For those unfamiliar with the details of the used car warranty, it doesn't cover engine components should the failure be caused by a non-covered component. The fan is covered, but by a different warranty.
Thoughts? I get that it may or may not be covered depending on what mood the Nissan rep is in at the time.
BTW - If anyone local to me has LS-related connections I'd appreciate that info
Old May 29, 2012 | 08:55 AM
djamps's Avatar
djamps
My fans failed and I never overheated (badly at least). It creeped up at red lights but never exceeded 220 and took a while to get there and dropped quickly once I was moving. This was in 100deg weather too. I do have an aftermarket radiator tho..
Old May 29, 2012 | 08:56 AM
terrasmak's Avatar
Why was it running when it went past the H mark? Even at 3/4 temp you should have shut it down.
Old May 29, 2012 | 09:19 AM
drivessidewayz
I wasn't aware it was that hot; it went up a lot faster than usual so by the time I checked it was too late.
Old May 29, 2012 | 09:55 AM
Vivid Racing's Avatar
Vivid Racing
Vivid Racing
If you want to go the V8 route, look at the LQ series engines too. Cheap V8 powahhh!
Thoughts on keeping a VQ? Just buy a used one from a reputable member here or a trusted vendor. Unless you plan on going FI VQ. In that case, use this opportunity to build a solid bottom end.
Old May 29, 2012 | 11:53 AM
drivessidewayz
Yea, it's either a v8 swap or FI...most likely v8 though due to the ease of making power.
Old May 31, 2012 | 02:31 PM
ocdz's Avatar
ocdz
Weren't you running a big nitrous system at one time? Was it on the car at the time of failure?
Old Jun 1, 2012 | 12:41 PM
drivessidewayz
There was no aftermarket anything on the engine at time of failure except intake and exhaust...which I never count, lol. Anyway, the issue here is that the engine overheated and subsequently failed because the fan failed; while fi or something of the like may have accelerated internal wear, it was the fan that actually caused the failure.
Old Jun 1, 2012 | 01:02 PM
KornerCarver's Avatar
KornerCarver
What were the symptoms of the fan failure? I'm not sure how you would know that occurred and caused the overheating.
Old Jun 1, 2012 | 01:17 PM
terrasmak's Avatar
So you blew it up while it was parked with the engine running? The fan does nothing while the car is moving
