Exedy NM072HD install
Old Jul 13, 2012 | 09:53 AM
Solitude's Avatar
Solitude
Default Exedy NM072HD install
Looking for any and all advice before I start this project. Just hoping to find any issues and be prepared for before they show up, while installing this stage 4 clutch kit and flywheel.
Old Jul 13, 2012 | 10:09 AM
STL 350Z's Avatar
STL 350Z
If this is a clutch install there is A LOT of information here... search.
Old Jul 13, 2012 | 10:13 AM
STL 350Z's Avatar
STL 350Z
https://my350z.com/forum/search.php?searchid=15771334
Old Jul 13, 2012 | 11:13 AM
tpinto0260's Avatar
tpinto0260
One thing that you should be aware of is the alignment of the flywheel. The flywheel has a pickup point that interface with the crank angle sensor. if you do not clock the flywheel in the correct position it throws the sensor off and the car will not run correctly.
