Removed Nats Need to Wire In Switches Guide
Old Jul 30, 2012 | 08:29 AM
350zJDMnismo27's Avatar
350zJDMnismo27
Smile Removed Nats Need to Wire In Switches Guide
Any one have a guide to wire in toggle switches. I need to know which wire run power to ecu and ignition.
Old Jul 30, 2012 | 12:20 PM
350zJDMnismo27
So per FSM its looks like. Correct me if I am wrong
116 pin= Ground
120 Pin= ECU Power
109 pin= Ignition
62 pin= rpm read out
113 pin= fuel pump
Old Jul 31, 2012 | 04:23 AM
MR RIZK's Avatar
MR RIZK
^^ There are a few pins for power. Have a look at page 16 of the haltech manual or FSM for clarification. Not sure if u need both etc
http://files.haltech.com/downloads/p..._Z33_Rev_4.pdf
Old Jul 31, 2012 | 07:16 AM
eZg's Avatar
eZg
You wiring in a "Mad Max" kill switch??
I always thought he kinda cut off his nose to spite his face.
Old Sep 21, 2012 | 03:56 AM
mw9's Avatar
mw9
116 pin= Ground
120 Pin= ECU Power
109 pin= Ignition
113 pin= fuel pump
So did you get everything worked out? Did you eliminate the BCM? This is the next phase of the my build eliminating the NATS and rewiring
350Z_Al
Oct 29, 2020 07:44 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Depravity
Oct 1, 2015 04:49 PM
