Thinking about cams....
Old Aug 13, 2012 | 08:31 PM
m808six's Avatar
m808six
Default Thinking about cams....
was wondering if there was a good street cam that I could run WITHOUT building the motor any further... just a drop in cam with a decent lift that would show some positive results...
tanks in advance for the info...
Old Aug 13, 2012 | 08:36 PM
m808six's Avatar
m808six
forgot to mention, i will be installing a vortech some time within the next few months so the build will not remain NA for long.... not sure if that matters but i'd think it would
Old Aug 14, 2012 | 09:30 AM
silvertouringz's Avatar
silvertouringz
im running Brian Crower stage 2 on a stock engine with boltons and uprev tune. the car is very streetable and its my dd
Old Aug 14, 2012 | 10:31 AM
m808six's Avatar
m808six
what kind of numbers are you putting down? did you also add springs and retainers?
whats your redline?
thanks for the reply!
Old Aug 14, 2012 | 12:25 PM
graffkid732's Avatar
graffkid732
Stock block vortech? I wouldn't waste time or money on cams. It's not a quick job on the vq.
Old Aug 15, 2012 | 07:00 PM
binder's Avatar
binder
+1
worst money to hp ratio on our cars is cams. These aren't domestics that cams can be swapped in a couple of hours. The whole front of the engine has to be pulled. IIRC when my friend looked it up at the dealership it was 9 hours of flat rate work. I've torn down my heads to replace the gasket with the engine in the car and it's definitely not an easy or fast job to get the cams out. I would have never put cams in my car if the engine wasn't already torn down. I think most shops charged around 1200$ for a cam swap.
Old Aug 16, 2012 | 09:38 AM
silvertouringz
whats your redline?
still ddnt dyno it. waiting to re-tune it with vince of R/T. BC stage 2 doesnt need springs and retainers. I have 1 map set at 7300 which i rarely use, the other set at 7000 which i use daily.
lapham3
Oct 7, 2022 03:15 PM
Alexreyes
Sep 30, 2015 11:30 PM
