Wire Tuck (front coolant hose)
Old Oct 17, 2012 | 05:16 PM
suprasam's Avatar
suprasam
Originally Posted by Voboy
You can buy a pack of rubber ones with multiple sizes from any corner parts store like Advance auto for about 5 bucks. It has the correct size to plug that hose.
Another option is to just buy a longer line and route it however you want. The line and hose clamps are cheap, again you can get them at any corner parts store.
That's what I did originally. No operational issues, but the rubber ones will rot over time. quicker if there are a lot of drastic weather changes. Fine if you keep an eye on it.
I had previously ordered the wrong diameter silicon hose for something else which happened to be long enough to go over the wire loom location. either way is good.
Old Oct 17, 2012 | 08:17 PM
350zjason350z's Avatar
350zjason350z
Know it all
I didn't read it at all... But thanks for the info
Old Oct 17, 2012 | 08:34 PM
KingBaby's Avatar
KingBaby
Hardest Setting
Interesting comeback
Old Oct 18, 2012 | 06:38 AM
cturnbull802's Avatar
cturnbull802
i was hoping the ones that i ordered would be rated for coolant use and hopefully hold up a bit better. i have used the smaller help section caps before and they fall apart fairly quickly on coolant use, they work fine for capping off vacuum lines.
Old Oct 18, 2012 | 07:08 AM
Nismo44512's Avatar
Nismo44512
It may seem like a simple delete, but i've searched the fourm for a "Coolant line delete" and nothing came up. Could someone post a DIY how to do this?
Old Oct 18, 2012 | 07:10 AM
cturnbull802
unhook coolant hose from the front of engine and cap the ends?
Old Oct 18, 2012 | 07:12 AM
Nismo44512's Avatar
Nismo44512
that's it? I figured it'd be a little more complicated lol
Old Dec 29, 2017 | 12:38 AM
rottingcat's Avatar
rottingcat
who said it was 16mm...i measured and it was 3/4 inch....
Obadabot
Jun 18, 2023 11:31 PM
350Z_Al
Oct 29, 2020 07:44 PM
