Need advice for my new Clutch + Flywheel Combo
Old Oct 29, 2012 | 11:46 AM
lucasbroderick's Avatar
lucasbroderick
Default Need advice for my new Clutch + Flywheel Combo
My current setup is slipping, with a clutch burning smell...so it has to go soon. I'm in the market for a whole new setup. My old setup was a JWT clutch and flywheel.
I am looking for a clutch and flywheel combo that's cheap as can be (even lightly used), works for a stock 2004 350z, and doesn't chatter like this JWT flywheel does.
What brands should I be looking at? Where can I find a good deal?
EDIT: http://www.clutchstar.com/product/gr...04-nissan-350z
http://www.f1clutch.com/product.html...-g35-350z-2004
These looks like good deals, but I have no idea what I'm doing when it comes to clutch parts. Hopefully someone can give me insight so I don't waste my money. Any help is appreciated.
https://my350z.com/forum/drivetrain/...e1-clutch.html
Found this on the forums...I'd obviously need to get a new Flywheel, but would this work for the clutch replacement?
Old Oct 29, 2012 | 12:32 PM
hellman_x's Avatar
hellman_x
Are you FI? If not, why don't just get OEM style?
Old Oct 29, 2012 | 12:48 PM
lucasbroderick
I am not against getting OEM. Whatever's cheaper.
Old Oct 30, 2012 | 06:33 AM
binder's Avatar
binder
Find a used oem flywheel since the lightened JWT flywheel is what causes noise(vibration) then get a low grade ACT clutch for cheap. That would be the cheapest option. I think most users on here would give you an oem flyhwheel if you pay shipping. OEM quality ACT clutches are around 200ish or something.
also, you can re-use your JWT pressure plate. The ultimate cheapest route would be buy a new friction plate from JWT and then get a free OEM flywheel.
Old Oct 31, 2012 | 12:08 AM
stascom's Avatar
stascom
How many miles did you put on the kit? How did you drive?
Old Oct 31, 2012 | 09:24 AM
lucasbroderick
The previous owner installed it, and I bought the car with 35,500 miles on it. So I'm not sure at what point he put the kit in. I myself put 20,000 miles on the car, most of those being road trips with cruise control on. I don't drive like an old person, but I don't track the car, either. So right now, 55,500 miles on the car.
Old Nov 3, 2012 | 12:27 PM
Jbakes727's Avatar
Jbakes727
Dam 55k and your already on your third clutch? I hope this car wasn't abused. I'm still running stock with 81k
Old Nov 8, 2012 | 06:36 AM
RyuuChi's Avatar
RyuuChi
Holy crap dude, i got 100k on my original oem clutch and its still going relatively strong...
Old Nov 9, 2012 | 01:23 PM
ZSpeedPerformance's Avatar
ZSpeedPerformance
Vendor - Former Vendor
What's your budget? Im sure I can get you in something MUCH better than the kits you mentioned.
Stock replacement and South Bend Flywheel if you want to rid the noise, Also put good fluid in it and it will be pretty quiet with the South Bend.
Old Nov 9, 2012 | 01:26 PM
ZSpeedPerformance
If you don't mind a stiff pedal feel
Low Cost, High TQ
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
