NISMO 46cc Heads inspected... to be installed \m/, ^_^ .\m/
Old Apr 11, 2004 | 06:41 PM
  #101
turbo-maxima's Avatar
turbo-maxima
After the clean out your bank account maybe 50-60 whp.
Old Apr 20, 2004 | 04:24 PM
  #102
downforce's Avatar
downforce
What is the stated compression ratio, from nismo, with this head?
Old Apr 20, 2004 | 09:06 PM
  #103
UsafaRice's Avatar
UsafaRice
I don't know if Nismo has put out the stated CR, but I come out to 12.6:1 with a 46cc chamber in them. This is using the engine volume of 3,498 cc. I don't know what the piston top is shaped like, but the Nismo head will definitely be between 12.4 and 12.7 to 1.
Old Apr 21, 2004 | 04:19 AM
  #104
pimp1911's Avatar
pimp1911
Would the stock pistons have to be changed. And with compression that high. Would you have to switch to race gas. I am sure the ECU would have to be flashed.
Old Apr 21, 2004 | 06:10 AM
  #105
turbo-maxima
You might be able to get away with ecu tuning but I doubt it will run on 93 octane. You might be able to get away with a N/A alchohol/water injection system. Those can be bought for 200 dollars. I think I have a link at my website, one sec. http://www.racetep.com/wik.html $300 dollars my bad. Good price though.
Old Apr 21, 2004 | 10:55 AM
  #106
alpine's Avatar
alpine
Default I got my car back Temporarily...
For testing purposes...
The audio system rocks!
Old Apr 21, 2004 | 12:59 PM
  #107
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
93 or 94 octane could run a 12:1 engine - I would run it on 100 though to be on the safe side
Old Apr 23, 2004 | 06:21 AM
  #108
downforce's Avatar
downforce
bump
Old Apr 23, 2004 | 07:05 AM
  #109
turbo-maxima
It is already hard for some of ou 350z with bolt-ons trying not to lean out too much. Some of you'll are getting 14:1 air/fuel ratios. That is pretty high, I doubt you can run street gas.
Old Apr 23, 2004 | 07:25 AM
  #110
downforce's Avatar
downforce
Default too lean
I haven't read it yet, but a magazine that i just picked up has an article that talks about injector sizes. It asks the question does your car have the correct injectors for the target hp you are trying to achieve?
Could this be a question/step that some are neglecting to address?
Old Apr 23, 2004 | 08:29 AM
  #111
turbo-maxima
I don't know does no someone who has lots of power on stock injectors. You might be able to get away with a high flow fuel pump with the increased compression. I don't think you need bigger injectors.
Old Apr 23, 2004 | 08:42 AM
  #112
downforce's Avatar
downforce
I'll read the article about the injectors and post some info on what it has to say.
Old Apr 23, 2004 | 01:05 PM
  #113
turbo-maxima
"Nissan Motorsports just released a new head which has the VQ30DE chamber volume but the VQ35DE ports and titanium valves which raises the compression ratio to 12:1 if you’re interested in building a naturally aspirated Maxima."
Quote from www.nissanperformancemag.com
Old Apr 24, 2004 | 07:57 AM
  #114
turbo-maxima
bump
Old Apr 24, 2004 | 08:37 AM
  #115
alpine's Avatar
alpine
bump
Ok I haven't had the time to figure this out, I'm assuming there is some kind of internet tracking/tagging thing going on here, but what is going on with this "bump" thing?
Sorry if this is a stupid question.
Old Apr 24, 2004 | 01:32 PM
  #116
Z1 Performance
Former Sponsor
it simply brings the post back to the top of the topic list in its given category
Old Apr 24, 2004 | 01:57 PM
  #117
Street Visionz, Inc.'s Avatar
Wait, so wouldn't this mean that, as you stated before, the VQ30 head would do this on a VQ35 engine? If so, has anyone tried fitting a VQ30 head onto the VQ35 block and if so does it fit? What other problems except fitting might I run into if I try this? For example, let's say it fits on perfectly, can I blow my motor if I turn it on due to some other problem? lol sorry i know that sounds like a stupid question.
Old Apr 24, 2004 | 05:58 PM
  #118
turbo-maxima
You might crack a piston because of the high compression. You might want to run some race gas before you have a chance to tune it. Then after you get it tuned you might be able to run 93 or 94 octane. There are 2 maximas going to do it in about a month.
DON'T BUY NISMO!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Go find a VQ30 from a maxima at a junkyard then switch them out. 200 dollars from junkyard, 500 for port and polish and 200 for 3 angle valve job. If you can find the titanium valves from a Q45, them them son of bitches in there too. Cost 1/3 to 1/2 the price.
Old Apr 24, 2004 | 09:40 PM
  #119
Okay even with tuning would I be able to run the car on 91 octane? By swapping the VQ30 head in, won't I lose the Continuously Variable Valve Timing Control. Also can you explain what you mean by 3 angle valve job and would I be using the valves from the vq30 or vq35? Also while I'm in there shouldn't I swap to better springs and cams?
Let's say I swap the VQ30 head in after getting it ported and polished, get the valve job done, swap in new springs and retainers, get the ecu reflashed and redline extended to 7100, swap in some JWT cams, how much wheel hp am I looking at?
Old Apr 24, 2004 | 11:31 PM
  #120
Resolute's Avatar
Resolute
The VQ30 heads do not flow as well as the VQ35 heads do. The VQ35 heads stock are close to what these RZZ heads will flow, but the VQ30 will not come close to these NISMO heads. This swap will also require the front chain cover to be replaced and yes, you will lose the CVTCC system on the VQ35. Second, the wiping pad on the VQ30 buckets are not as large as the what can fit on the VQ35 or the RZZ, which is a damn good reason why the Formula Nissan series do not use ported VQ30 heads on the VQ30 blocks when they rev to 10,000 rpm. Food for thought.
