NISMO 46cc Heads inspected... to be installed \m/, ^_^ .\m/
Old Apr 27, 2004 | 03:25 PM
  #141
scz's Avatar
scz
Originally posted by x350Zx
Okay even with tuning would I be able to run the car on 91 octane? By swapping the VQ30 head in, won't I lose the Continuously Variable Valve Timing Control. Also can you explain what you mean by 3 angle valve job and would I be using the valves from the vq30 or vq35? Also while I'm in there shouldn't I swap to better springs and cams?
Let's say I swap the VQ30 head in after getting it ported and polished, get the valve job done, swap in new springs and retainers, get the ecu reflashed and redline extended to 7100, swap in some JWT cams, how much wheel hp am I looking at?
I just saw this post and thought I would answer for anyone else who wants to know. A ? angle valve job refers to where the head of the valve seats. The optimal seal for a valve would be a totally rounded off valve seat. Since this is nearly impossible, they grind the seats flat on many different angles. That is why many people say they are getting a 3-6 angle valve job. Each costing more and more money because of the talent involved. So with each increasing number of angles, you are in essence trying to make a more rounded off edge for the head of the valve to seat on. I hope I explained that well enough to visualize.
Old Apr 27, 2004 | 09:02 PM
  #142
scz's Avatar
scz
Old Apr 28, 2004 | 02:00 PM
  #143
turbo-maxima's Avatar
turbo-maxima
^ Double Post
Wow 6-angle valve job has to be expensive. How much are the nismo blanks. They would have to be like buying new cams. So $1000 plus the cost of regrinds with is about $150-$200 per a cam from crane. So about $600-$800. So this is definatily race application, that is mucho money.
Old Apr 28, 2004 | 02:26 PM
  #144
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
the cams come as blanks though, so I don't know if you can just regrind them, or if its more specialized than that?
Old May 5, 2004 | 10:19 PM
  #145
downforce's Avatar
downforce
Lightbulb INJECTORS
There was absolutely too much information in an article about injector sizes that i read in GRM magazine, so you'll have to get it or go to there website to read it, basically addressing the issue of injector size. In short it stated that engineers use the smallest injectors for the target hp. (for multiple reasons; fuel efficiency, smooth idle at low rpm and emissions) If you start adding hp with bolt-ons you could be running too lean (regardless of the octane) and not getting the full benefit of your hard earned money you spent on all those parts and eventually ruin your engine in the process! So basically if your adding hp you need to use the formula they give, which they state is an industry standard, get the appropriate size INJECTORS adjust your timing and get an ecu flash as necessary.
Old Jun 6, 2004 | 05:37 PM
  #146
SR20DEN's Avatar
SR20DEN
VQ30DE Steel valve;
Face In: 36.0 - 36.3mm
Face Ex: 31.2 - 31.5mm
Stem In: 5.965 - 5.980mm
Stem Ex: 5.945 - 5.960mm
Length In: 97.32 - 97.82mm
Length Ex: 94.85 - 95.35mm
Valve seat angle 45º15' - 45º45'
VK45 Titanium valve;
Stem In: 5.972 - 5.980mm
Stem Ex: 5.962 - 5.970mm
Length In: 96.57mm
Length Ex: 94.50mm
Old Jun 6, 2004 | 05:40 PM
  #147
SR20DEN's Avatar
SR20DEN
VQ35DE Steel valve
Face In: 37.0 - 37.3mm
Stem Ex: 5.955 - 5.970mm
Length In: 96.12 - 96.62mm
Length Ex: 93.65 - 94.15mm
Well it appears that I ahve been beaten to the punch of playing around with VK45 valves. I plan to see what is involved in fitting the VK45 exhaust valves into some stock VQ35 cyl heads. New shims should do the trick.
Old Jun 30, 2004 | 08:14 PM
  #148
pimp1911's Avatar
pimp1911
Bumping to keep hope alive. Lol.
Old Nov 16, 2004 | 05:29 PM
  #149
krismax's Avatar
krismax
what is the deal with these? Im dumbfounded that there is no interest in these?
Old Nov 16, 2004 | 05:43 PM
  #150
Z1 Performance
Former Sponsor
have you seen the price of these?
Old Jan 18, 2005 | 03:31 PM
  #151
430ztt's Avatar
430ztt
hey has anyone successfully installed these heads yet? If so what all is required to do so? What were the gains? I WAS interested in these but after reading this thread I think my interest has gone more the the AEBS stroker kit....
nanotech
Oct 2, 2015 05:02 AM
