Coolant overflow tube
Old Jan 23, 2013 | 11:14 AM
mike_eee's Avatar
mike_eee
Default Coolant overflow tube
Hello Guys,
I want to replace my coolant overflow tube, the small dia tube that runs on the top of the radiator, connecting the coolant overflow tank and the radiator neck.
I want to replace it with a silicon tube, and wanted to know, what dia tube to buy and from where. Most do sell as a set and i do not want the set cause i do have the other tubes.
Z1 sells silicon tubes but I am not sure what dia to buy. they have two dimensions 1/4 and 5/16 ..please advice which to buy..
http://www.z1motorsports.com/350_g35...sort=6a&page=2
Mike
Old Jan 23, 2013 | 12:53 PM
bealljk's Avatar
bealljk
Like a colored silicon hose? Is something wrong with a diameter correct black hose you'd get from the autoparts store?
I will check mine tonight if you don't have an answer by then.
update…
My OEM hose on my 2003 touring is 8.8mm ID and 13.1mm OD...
Chris350z03
Oct 8, 2023 07:19 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
SharX59
Sep 27, 2015 09:23 AM
smithmt3
Sep 11, 2015 08:25 PM
juang20
Intake
Sep 7, 2015 05:37 PM
