Rogue Enginering short throw shifter review
Old Jan 21, 2004 | 02:32 AM
jmark's Avatar
jmark
Thanks DeeZee. Sounds like another item to add to my growing list......
Old Jan 21, 2004 | 01:38 PM
DeeZee's Avatar
DeeZee
No problem man! i like to help the few times i can! i gotta say though, i REALY wasnt impressed with the s2k over all?
Old Jan 21, 2004 | 02:51 PM
silverstoneTT's Avatar
silverstoneTT
Ok now I'm definetly excited. I just went today to Rogue's location in Hohokus and picked my shifter up from Ben who had been expecting me. He is a really cool guy and very helpful. He was talking to me about the install and how I would go about getting the bolt with ease as Im not at all mechanically inclined. Im planning on putting it in this weekend and will post a review then.
Old Jan 21, 2004 | 06:34 PM
jmark's Avatar
jmark
BJ,
Will you guys be racing with a Rogue shifter in the Z?
Old Jan 21, 2004 | 08:06 PM
DeeZee's Avatar
DeeZee
he already is!
Old Jan 22, 2004 | 02:30 AM
jmark's Avatar
jmark
Old Jan 22, 2004 | 08:51 AM
etang789's Avatar
etang789
Originally posted by DeeZee
yes, you will. there is 1 bolt you will need to remove. not very hard at all. the whole job start to finish was only 30min! i still cant belive the difference in feel! i just love it! did you order the new cup as well? i DEFINATLY recomend it! let us know what you think after you get it in. mine was here two days after i ordered too, so you should be reciving it shortly. i promise your going to LOVE it!
What does the new cup do?? how much is it? shouldn't it come with the new ssk?
Old Jan 22, 2004 | 07:30 PM
DeeZee's Avatar
DeeZee
its only like $10. bj (350evo.com) told me that i could use my stock cup, but there is always a chance you could break it removing it! its not going to come off very easy TRUST ME! it just made the job a little easier! i didnt want to break mine, then wait for a new one!
Old Jan 25, 2004 | 06:51 PM
rucorey's Avatar
rucorey
Your lucky to have gotten the new shifter. Santa brought me one and it's got some play (twists). I think the rubber insert is not fully attached.
Anybody else have the old style shifter without the bolt? Is there any play?
Old Jan 25, 2004 | 08:31 PM
DeeZee's Avatar
DeeZee
bj said there were 3 reported shifters with this problem in the old style shifter. but they have been fixed. give him a call, im sure he will fix it for you! he has A++ customer service!! how hard did you tighten your shifter **** down? the seperation problem would most likely be to to OVER torquing it! but regardless, bj will make things right! those 3 shifters were the reason the RE shifter was redesigned.
Old Jan 26, 2004 | 04:57 AM
John's Avatar
John
Mine is the old style, and I have absolutely no problems whatsoever.
Old Feb 16, 2004 | 02:59 AM
tremayne's Avatar
tremayne
Hi!
I'm certainly impressed by the review. Couple of questions though , is it possible to use the standard gear **** with the RE shifter? Also - what is a cup?
many thanks from England!
Old Feb 16, 2004 | 05:03 AM
John's Avatar
John
The thread pitch on the Rogue shifter is the same as the OEM one, so any **** will fit (the OEM one included). The "cup" is a plastic cup that the fulcrum bearing sits in. The plastic is a bit stiff and brittle, so when you remove the it the cup may break.
Old May 18, 2004 | 05:50 AM
jmark's Avatar
jmark
I had BJ install the Rogue shifter while I was at their shop. I am very happy with it.
Old May 25, 2004 | 09:23 AM
Z BOY's Avatar
Z BOY
Can someone with experience with BOTH the RE and B&M short shifters give me some feedback on pros and cons of each? B&M's throw is shorter and unit costs about $80 less than RE.
Old May 26, 2004 | 09:29 AM
o snap its eric's Avatar
o snap its eric
bumo because im intrested too with the comparision
Old May 26, 2004 | 02:08 PM
jak's Avatar
jak
I would like to see a comparison to. Anyone out there that has used both or experience with both?
Jeff
Fixxxercask
Nov 9, 2015 11:10 AM
