low clutch engagement
Old Mar 10, 2013 | 09:13 PM
superlim9's Avatar
superlim9
Default low clutch engagement
Just replaced my 05 Enthusiast clutch with an Exedy OEM kit and changed the line to full SS Braided from the master all the way to the slave and now the engagement point went from high side with OEM to low side with new setup. Just wondering if those that did a restrictor delete had the same result.
Old Mar 11, 2013 | 07:52 AM
AngelsVQ's Avatar
AngelsVQ
did you make sure to bleed all the air out of the lines? if so then you might have to adjust your clutch engagement a bit
Old Mar 11, 2013 | 08:00 AM
superlim9's Avatar
superlim9
System is fully bled... stock pedal not rjm and it is functioning properly
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
