Ignition coil pack resistance?
Old Mar 29, 2013 | 10:40 AM
blAk mAx's Avatar
blAk mAx
Default Ignition coil pack resistance?
Going to chek out my ignition coil packs with a multimeter. Anyone know what the resistance in ohms should be for a good or bad? I've tried searching and just get sites selling new coils. Called Infiniti and they said their techs would have to search online but cant do that at this time. Called some shops and said to look for any burning or bubbling. I've had code p0300 for about a year now. Thinking its coils or injectors
Old Mar 29, 2013 | 11:29 AM
amr_electron's Avatar
amr_electron
From the FSM,
Old Mar 29, 2013 | 12:20 PM
blAk mAx's Avatar
blAk mAx
So anythin but 0 is bad?
Old Mar 29, 2013 | 01:51 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
yeah. What i would do is measure all your coilpacks and see if any of them are way out.
0 means shorted, infinity means open.
Wonder if measuring the capacitance would be better.
Old Mar 29, 2013 | 02:43 PM
blAk mAx's Avatar
blAk mAx
Pretty much got 1.7 on 5 and one was 1.9
Old Mar 29, 2013 | 04:47 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
Measure the capacitance?
Old Mar 29, 2013 | 05:13 PM
blAk mAx's Avatar
blAk mAx
i dont think so. i just tested the 3 prongs on the ignition. should there be 2 reading for primary and secondary?
Old Mar 31, 2013 | 01:23 PM
binder's Avatar
binder
except zero means the coil is good as long as it has resistance (which means continuity). So 0 is bad, everything else is good.
Old Mar 31, 2013 | 02:45 PM
blAk mAx's Avatar
blAk mAx
Should there be 2 reading with the 3 pins? Primary and secondary?
Old Aug 28, 2017 | 07:37 AM
steveg350z's Avatar
steveg350z
so I got the p0303...went to check out the #3 coil...removed coil pack and smelt burnt wiring in the pack. probably obvious that it's shot because of the electrical burnt odor...but for ***** and giggles tested resistance....im not a pro...but good instruction taught me how to get this far. so I'm getting 1.62 1 to 2 pin....and 0 on 1 to 3 pin and 0 on 2 to 3 pin. just looking for a verification from someone that this is the issue. thanks
Dr.Paulyy
Jul 29, 2019 07:45 AM
sales@czp
Suspension
54
Jan 17, 2018 09:24 PM
derekinthez
South East
Sep 28, 2015 06:35 PM
