ECU reset and timing advance.
Old Jan 26, 2004 | 03:06 AM
joust75's Avatar
joust75
Default ECU reset and timing advance.
Hi all!
I had the shop bump my timing +2. I want to try resetting my ECU, but am concerned that the timing will revert to normal. I dont have a 7000$ consult 2 so of course I dont want this to happen.
how about it? If I reset ECU will timing go back to stock?
Old Jan 26, 2004 | 07:56 AM
can350z's Avatar
can350z
Default No.. go ahead and reset...
You can use the Consult to clear the self learn memory or leave your battery disconnected for a couple of hours... Does not impact the timing change...
Old Jan 26, 2004 | 10:08 AM
zxsaint's Avatar
zxsaint
Fairlady Stalker
Anyone know if disconnecting the battery will erase the homelink programming?
Old Jan 26, 2004 | 10:36 AM
Zzzow!'s Avatar
Zzzow!
I had my battery disconnected for 10 hours when I installed my seat covers, homelink still worked.
Old Jan 26, 2004 | 10:44 AM
FLY BY Z's Avatar
FLY BY Z
homelink is run by a little battery in the mirror assembly.
Old Jan 26, 2004 | 11:27 AM
moog's Avatar
moog
Can Nissan dealers advance the timing in G35s too?
Old Jan 26, 2004 | 01:30 PM
zxsaint's Avatar
zxsaint
Fairlady Stalker
Thats excellent -- didn't really want to reprogram that. Thanks for the info!
Old Jan 26, 2004 | 02:14 PM
joust75's Avatar
joust75
yup!
Old Jan 26, 2004 | 03:05 PM
alphared's Avatar
alphared
what does advancing the timing do
Old Jan 26, 2004 | 04:06 PM
edubbzzz's Avatar
edubbzzz
I mean what exactly do you do ask a nissan tech to grab a consult 2 and tell them to advance you timing, BUT if you were running FI wouldnt you want them to retard the timing.......
I dont know i have a hard enough time when i go in there to have them reset my SES for that DAMN GAS PRESSURE CODE......
Old Jan 27, 2004 | 05:06 AM
MustGoFastR's Avatar
MustGoFastR
I don't suppose anyone can list the exact procedure the tech has to do to advance the timing? My tech can't figure out how to do it.
Also, will the 2 deg advance benefit an engine running the Crawford Plenum only?
Old Jan 27, 2004 | 05:08 AM
FLY BY Z's Avatar
FLY BY Z
It's probably ok to do it with a plenum but that is just going to bring you that much closer to pinging. I had mine advanced but returned to stock timing since the power gain was hardly noticeable and with more mods I don't want any detonation.
Old Jan 27, 2004 | 07:06 AM
VandyZ's Avatar
VandyZ
Do not advance your timing. TRUST ME. You will make better power with stock timing .
This is your free tip of the day.
You are all welcome!
Old Jan 27, 2004 | 07:13 AM
PhoenixINX's Avatar
PhoenixINX
Originally posted by VandyZ
Do not advance your timing. TRUST ME. You will make better power with stock timing.
Giving away all the secrets now eh????
Old Jan 27, 2004 | 07:27 AM
VandyZ's Avatar
VandyZ
Fixed it, but its not like someone else has not told other flashers (not bewbies).
Old Jan 27, 2004 | 07:52 AM
PhoenixINX's Avatar
PhoenixINX
I have said nothing.
Old Jan 27, 2004 | 07:54 AM
VandyZ's Avatar
VandyZ
Not you! Thanks for playing please try again!
Old Jan 27, 2004 | 11:46 AM
joust75's Avatar
joust75
ITs not something you can do without the 7000$ interface. With the consult 2 its simple. Without.... forget it!
Old Jan 27, 2004 | 12:09 PM
sschmuve's Avatar
sschmuve
"Do not advance your timing. TRUST ME. You will make better power with stock timing.
This is your free tip of the day."
Hey!....what's the big secret?
Old Sep 23, 2004 | 01:33 PM
cyberz350's Avatar
cyberz350
Can they retard timing withthe Consult II?
