Vehicle speed sensor question
Old Oct 15, 2013 | 05:32 AM
emas9420's Avatar
emas9420
Default Vehicle speed sensor question
Ok so I know you guys get this question a million times but bare
with me. I'm thinking about buying a speedo corrector (speedodrs). I've emailed them asking if it would work for my 07 z and they said that as long as it's a 3 wire Hall effect sensor then it would work. My question is, do our cars have the 3 wire sensor like most cars? And if it does , would splicing in to the wires on the white box under the radio work or should I go directly to the gauge cluster? Thanks
Old Oct 16, 2013 | 05:30 AM
emas9420's Avatar
emas9420
Bump?
Old Oct 17, 2013 | 10:39 AM
PerfZ's Avatar
PerfZ
A million times? First time in 10 years for me, and I had to google what you were referring to. May I ask why you are even bothering with that?
Old Oct 17, 2013 | 12:43 PM
dcains's Avatar
dcains
The white box under the radio is for the HVAC, at least AFAIK. What gave you a different idea?
Also, there is one speed sensor on each wheel, and nothing on the driveshaft or pumpkin (as with some other cars). How would you know which sensor to use? And, if you did tap into one of those, you would screw up the ABS and TCS/VDC (if applicable to your car).
Old Oct 17, 2013 | 12:56 PM
Syner's Avatar
Syner
What are you trying to achieve?
Old Oct 17, 2013 | 01:18 PM
dcains's Avatar
dcains
Probably to correct for poorly-sized wheels/tires???
Old Oct 17, 2013 | 05:51 PM
emas9420's Avatar
emas9420
My speedo is off and I want to correct it cause it's also taking a toll on my mileage
emas9420's Avatar
emas9420
I saw an install for a HUD and they tapped into a wore on the white box
Old Oct 17, 2013 | 05:52 PM
emas9420's Avatar
emas9420
Fix my speedo
Old Oct 17, 2013 | 08:59 PM
dcains's Avatar
dcains
I drove my car once with the waterfall disassembled, and all the gauges worked fine. So, unless the install was just looking for a switched 12V+ source, or perhaps a source of switched power for illumination, I can't think of any reason to mess with that ribbon cable.
Old Oct 17, 2013 | 09:01 PM
dcains's Avatar
dcains
Fix my speedo
We know that - the question is why is the speedo reading incorrectly? Better to fix the problem than treat the symptom. Tire sizes???
Old Oct 17, 2013 | 09:14 PM
samsniss350z's Avatar
samsniss350z
I'm presuming its running out over and above the percentage error allowed? If so by how much is the error say at 30mph, 50mph and 70mph?
Old Oct 17, 2013 | 09:24 PM
terrasmak's Avatar
I would think the signal has to be changed between the computer that handles ABS/TCS/VDC and the gauge cluster. If only one wheel speed sensor was altered it would throw off the computer.
Old Oct 18, 2013 | 05:26 AM
Syner's Avatar
Syner
Like others have said, what is your tire size? Fix the problem, not the symptom.
Old Oct 18, 2013 | 05:32 AM
thekinn's Avatar
thekinn
I am interested in the OP's solution.. I'd rather not change my wheel/tire setup 18x9.5 x4. 275x35x18. My speedo reads about 5.5% faster than I am traveling.
Old Oct 18, 2013 | 05:38 AM
PerfZ's Avatar
PerfZ
He must be rolling 25's for it to be that big of a concern. And how can it mess up his mileage? A larger wheel/tire would result in the odometer reading less miles. Is that really an issue for you OP? I am assuming ( and hoping ) that you are not referring to gas mileage.....
Old Oct 19, 2013 | 07:38 PM
emas9420's Avatar
emas9420
It's reading faster so when It says 80 I'm doing 70. My tires are correct they just are 40 instead of 45. Odometer says I did 100 miles when I actually did (example) 50
Old Oct 19, 2013 | 07:39 PM
emas9420's Avatar
emas9420
It's on the white box under the radio. If you unplug it, ac won't work. They used it to get the speedo reading and also 12v
Old Oct 19, 2013 | 07:40 PM
emas9420's Avatar
emas9420
Don't have the money right now to get all 4 new tires considering they only have a few months in anyways. Yes I will change the tires but in the mean time I would like to fix this with the speedo corrector so my odometer doesn't say I did more miles then I actually do.
Old Oct 21, 2013 | 11:30 AM
emas9420's Avatar
emas9420
Ok. Well I bought the corrector anyways and it should be arriving soon. I will try to hook it up and report back. I haven't seen anyone attempt this on a 350z yet (atleast I didn't find anyone on the forum so this should be interesting)
