Aluminum Driveshaft
Old Nov 19, 2013 | 10:53 AM
-Campos-'s Avatar
-Campos-
Default Aluminum Driveshaft
found this browsing around on ebay this morning...pretty sure it should fit the Z. not sure.
http://www.ebay.com/itm/231097714884...84.m1555.l2649
Old Nov 19, 2013 | 11:09 AM
travlee's Avatar
travlee
Master
why would you want to replace the stock carbon fiber drive shaft with an aluminum one? the g35 drive shafts have an articulating knuckle in them, this is prob just to get rid of that and have a solid one. dont forget that the G's are also longer
Old Nov 19, 2013 | 11:33 AM
Syner's Avatar
Syner
^+1
Old Nov 19, 2013 | 12:17 PM
Nismo350z#0310's Avatar
Nismo350z#0310
Carbon fiber composite stock is excellent and can handle arguably as much or more power. Don't waste time and money on that.
Old Nov 19, 2013 | 12:35 PM
thisiswang's Avatar
thisiswang
G driveshaft doesn't fit Z anyway
Old Nov 19, 2013 | 02:23 PM
pyshin's Avatar
pyshin
Why did you even post this lmao wafj OP.
Old Nov 19, 2013 | 04:39 PM
Emski's Avatar
Emski
Because anything custom or aftermarket is ALWAYS ALWAYS better than stock. DUH.
Old Nov 19, 2013 | 04:40 PM
FamilyTradition's Avatar
FamilyTradition
not sure.
Old Nov 20, 2013 | 06:59 AM
stuartc323's Avatar
stuartc323
OP has been here since 2008, has 3 posts.
Old Nov 21, 2013 | 08:32 AM
str8dum1's Avatar
str8dum1
There's a reason why DSS never went into production with a 1 piece aluminum for the G35. The ebayer sells knows the reason and even sent it back to DSS for that problem.
Feel bad for whoever buys that...
Old Nov 21, 2013 | 08:59 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
gotta wonder if the op is the seller.
Whats the reason str8dum1? What causes it no to work.
Old Nov 21, 2013 | 09:01 AM
iideadeyeii's Avatar
iideadeyeii
OP is probably eBay seller
Old Nov 21, 2013 | 11:42 AM
JaE35z's Avatar
JaE35z
I have an aluminum DS on my 5at and it's pretty awesome..it's not made by this company, I have not a single issue. G35 of course. The original purchaser of this unit complained of it's balancing issues so this DS is probably defective
Old Nov 21, 2013 | 12:38 PM
djamps's Avatar
djamps
That's for a G35. Nobody in their right mind would make one for a Z which already has a WAY lighter CF drive shaft OEM.
abarclay
Wheels Tires
Sep 21, 2015 04:51 AM
EnjukuRacing
Drivetrain
Sep 14, 2015 11:15 AM
EnjukuRacing
Sep 11, 2015 08:34 AM
