cd009 trans reverse shift rod/fork ball bearings?
Old Dec 1, 2013 | 05:33 PM
iridebmx's Avatar
iridebmx
Default cd009 trans reverse shift rod/fork detent ball?
Wanting to know if anyone has taken apart their transmission and removed the reverse shift rod/fork and dealt with the 4 detent ball bearings that are in the holes in the rear housings mid-plate that fall out. I removed mine because my fork would not go out of reverse, but was somehow stuck in neutral and inspection of the rod was part of my search.
My Question is, does anyone know where the last detent ball bearing goes? Do two go in one hole? There are 3 slots on the rod and 3 openings in the rod hole BUT 4 bearings.
Thanks in advance to anyone who can help me out
Old Dec 21, 2013 | 06:03 AM
iridebmx's Avatar
iridebmx
anyone??? please??? just got around to getting back into my swap. need info!
Old Dec 21, 2013 | 04:41 PM
guitman32's Avatar
guitman32
Well, im not the most active member, but in all these years Ive seen very few threads where anyone has actually opened the CD00x transmissions...good luck sir!
Obadabot
Jun 18, 2023 11:31 PM
sherm
Apr 11, 2020 05:21 PM
