jwt clutch/flywheel proper break in procedure?
Old Dec 12, 2013 | 03:21 PM
Toneloc's Avatar
Toneloc
Default jwt clutch/flywheel proper break in procedure?
got the jwt clutch and flywheel combo in and I cannot find a thread on here that gives a definite answer... 300miles city driving? 500 miles city driving? stay under 3000rpm?
Please thanks
Old Dec 12, 2013 | 09:51 PM
cudaben's Avatar
cudaben
i don't know if they have some crazy secret way of doing this but traditionally you just take it easy for about 500 miles..
Me personally, i have probably changed 20 + clutches on my personal vehicles over that past 10 years. I have NEVER once followed the accepted break in procedure. I start it, cheek for leaks, then leave black marks on the road.
I have done all sorts of clutch from OEM, to crazy looking 3 puc clutches. Heat kills them.
You don't want to over heat clutch, ever. I.E. excessive feathering. It can glaze, similarly to a fan belt. If it glazes it wont grab as good.
Old Dec 13, 2013 | 07:46 AM
92K1500's Avatar
92K1500
I drove fairly easy on mine (no hard launches) for a few hundred miles but after just a trip around the block I poked the throttle in a corner to see if it was slipping or not.
Judging by how sideways I got I'm guessing it was holding pretty good.
Old Dec 15, 2013 | 08:09 AM
Toneloc's Avatar
Toneloc
im almost to the 500 mark...taken it easy and doing mostly city driving...then I will give a full review
Old Dec 16, 2013 | 06:25 PM
mcarther101's Avatar
mcarther101
I have never followed clutch break in procedure either, just so long as you're not tracking it from the get-go... you'll be fine.
You'll feel when the clutch is broken in most likely. Also, I'm on my 2nd JWT clutch /flywheel friction plate now, and the last one gave me a solid 75k miles, and I abused it pretty good. Just drove it hard from day 1.
Old Dec 23, 2013 | 01:26 PM
HK350 Z's Avatar
HK350 Z
Usually its no jack rabbit starts, no slipping the clutch, and no high RPM shifts for first 500...
Old Dec 23, 2013 | 02:56 PM
terrasmak's Avatar
Just drive, it's that easy
Depravity
Oct 1, 2015 04:49 PM
