More pull?
Old Feb 24, 2014 | 08:48 PM
  #41
GreyZ's Avatar
GreyZ
Originally Posted by 2TH PWR
maybe a winch?
Originally Posted by go7roo7
Really? You think you are the first genius to ask this ground breaking question, eh moon moon??
There are plenty of threads here and elsewhere that you can read ( and re-read) in your case, that will give you ALL THE INFORMATION you require.
Asking the same question again, doesn't make you special (well it does) it makes you a window licker.
lmao
Old Feb 25, 2014 | 04:46 AM
  #42
verdict.'s Avatar
verdict.
Originally Posted by Skipper2cold
Or I'm just working a part time job to get me through college.
Originally Posted by blue350zed
A stripper told me that once.
I was technically hinting at your age, not your actual occupation. We're giving you a hard time because you failed to search -- you could have easily found the answers you were looking for if you took several minutes to look around.
Old Feb 25, 2014 | 04:57 AM
  #43
terrasmak's Avatar
Originally Posted by Jennifer 2
The cruise control only monitors wheel speed that it gets from a sensor on the axle. I don’t believe it knows or cares which gears are in the differential case as it takes its reading farther down the line from that gear reduction.
The Barbie version has CC problems as documented in a couple gear threads. I believe they can only run up to. 3.7 's and retain CC
sherm
Apr 11, 2020 05:21 PM
Fixxxercask
Nov 9, 2015 11:10 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
reno56
Cooling System
Sep 19, 2015 11:34 AM
