CEL code # 274 and 283
Old Feb 1, 2004 | 02:49 PM
ChrisM's Avatar
ChrisM
Default CEL code # 274 and 283
Anyone know what CEL codes 283 and 274 are?
Thanks,
Chris
P.S. There maybe a 1 on front of those numbers, im not sure if im reading them correctly..
Old Feb 1, 2004 | 03:05 PM
John's Avatar
John
Does the Z have a service connector that you have to jump to read the flashing codes?
Old Feb 1, 2004 | 03:10 PM
ChrisM's Avatar
ChrisM
No, you do the standard ECU reset, but when the SES lights starts flashing, you start counting :-)
Please- anyone have those codes?
Chris.
Old Feb 1, 2004 | 03:40 PM
daking350's Avatar
daking350
Old Feb 1, 2004 | 03:46 PM
dougrace zs's Avatar
dougrace zs
Just checked the service manual...
Not finding these.
Old Feb 1, 2004 | 03:49 PM
ChrisM's Avatar
ChrisM
Can someone scan the pages from the manual and e-mail them to me? chrismachado@***.net
Thanks,
Chris.
Old Feb 1, 2004 | 08:38 PM
350zdanny's Avatar
350zdanny
I can't find those codes either. Are you sure those are correct?
Old Feb 1, 2004 | 08:40 PM
350zdanny's Avatar
350zdanny
174 is bank 2 lean condition.
183 has to do with the fuel tank temp sensor.
Old Feb 1, 2004 | 09:01 PM
ChrisM's Avatar
ChrisM
I am pretty sure im reading them right-
They are either
274 & 283
1274 & 1283
Can someone please e-mail me the pages out of the manual? Thank you daking, but I cant read what you sent....I would be in your dept if you could re-scan them
Thanks
Chris
Old Feb 1, 2004 | 09:21 PM
daking350's Avatar
daking350
They are either
274 & 283
1274 & 1283
Thanks
Chris
There is no code for that either..The only code with a 74 is
P0174 -Fuel System Lean-B2 (I have no clue!!)
P0183- FTT/Sen/Circut....(Dont ask...
Old Feb 1, 2004 | 09:28 PM
daking350's Avatar
daking350
Ah..FTT= Fuel Tank Tempature sensor....
the other one is fuel system too lean
Causes..
1)intake air leaks(did you recently install an intake?)
2)Heated o2 sensor(the one in the heads)
3)injectors(bad one)
4)Exhaust gas leak
5)incorrect fuel pressure(Clogged filter/bad gas)
6)Lack of fuel(same as 5)
7)MAF sensor
8)Incorrect PCV hose connection(see #1)
This is right from the service manual hope it helps..
Old Feb 2, 2004 | 05:55 PM
johnlotusboy's Avatar
johnlotusboy
OBDS-II error codes are all on this web site
etkms
Jun 19, 2022 06:30 PM
350Z Project X
Oct 17, 2015 05:16 PM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
Bigsyke
Sep 11, 2015 06:19 PM
