Output shaft play
Old Apr 2, 2014 | 05:21 PM
Deters's Avatar
Deters
Default Output shaft play
I noticed a "groaning" noise in the right rear that is rotational. Though it may be wheel bearing, will check tomorrow
I did look under the car though and the output shafts from the diff seem to have a little play from side to side, can "tilt" them just the slightest bit. Exact same amount of movement from each side..........Is this normal??
The noise seems to be only from the right rear.
m_0g
Jun 3, 2021 10:05 AM
bcoffee20
Nov 19, 2015 06:39 PM
Depravity
Oct 1, 2015 04:49 PM
TrackFiddy
Sep 24, 2015 09:36 AM
