Rattling on startup.
Old May 13, 2014 | 01:45 PM
3Ni5M0's Avatar
3Ni5M0
Default Rattling on startup.
What's going on guys. I searched the forums and found some threads that had questions similar to mine but I wanted to be exact. I have the same rattle as the one heard in this video. The rattle is temporary. I just recently put a new clutch and fly wheel in and a used engine. I had the sound before and I still have it now. Any suggestions or help pinpointing the problem would be great. I want to know if this is something I need to worry about. Thanks
Old May 14, 2014 | 09:08 AM
HK350 Z's Avatar
HK350 Z
From a thread a few threads down:
Johan, if you have a VQDE engine (2003 to 2005) this is not an uncommon problem and there is a TSB from Nissan explaining it. On a cold start one of the intake VTC (valve timing control) sprocket units can make a rattling sound for one second until it re-indexes. My 2004 did this every now and then for the ten years I owned it. I never bothered to replace it, as apparently it causes no long-term harm. I couldn’t find the 350Z TSB, but here is one for a Maxima that is similar.
http://maxima.theowensfamily.com/tsb/ntb03-060.pdf
This engine has a timing chain guide that tensioned by oil pressure, but it also incorporates a ratchet mechanism to keep it from losing tension when the engine is turned off. A problem with this unit will cause a more pronounced marble-in-a-can knocking sound that persists for longer than a few seconds at start-up.
lapham3
Oct 7, 2022 03:15 PM
Ryan Bonner
350Z Roadster
Sep 8, 2015 04:16 AM
PrototypeStan
Oct 25, 2002 06:00 PM
