How about another?! LSx Build Inside!
Old May 30, 2014 | 08:25 AM
bjr's Avatar
bjr
First LQ I've seen. Had to do a little catching up but that means it's an iron block 6.0?
If you want to gain any power out of it, it sounds like it was a good way to go for reliable NA power. I saw this quote on LStech from someone
"He said a LQ9 with full bolt ons, LS3 heads from TSP, LS3 intake, and a cam from TSP(we didn't talk about how big) can make 500rwhp"
Not sure how much $$ this would take - probably 1/2 again more than you've spent already! but it's got room to grow and respond better than the VQ.
Curious if you have any data of drivetrain weight before and after. How does it handle with an iron block driving hard around town? It has to at least be noticeable?
Old May 30, 2014 | 09:09 AM
mkiv20vt's Avatar
mkiv20vt
Absolutely. Heads, cam, tune and I should be sitting somewhere around 450-475whp. All of that for 2k give or take. I'm OK with that . This was the BIGGEST selling point for me.
From what I recall, weight is somewhat relative. (Someone correct me if I'm in left field). The car really doesn't feel that different in regards to cornering. Ride height is still the same with no adjustment to the coils.
Old Jun 28, 2014 | 03:29 PM
mkiv20vt's Avatar
mkiv20vt
Results are in!
341whp 372wtq. Very pleased with the outcome on essentially a stock motor.
Old Jun 28, 2014 | 03:49 PM
eZg's Avatar
eZg
I bet all that torque feels nice
Good job!
Old Jun 28, 2014 | 04:31 PM
ksuberk54's Avatar
ksuberk54
You could do a nice nitrous kit for cheap and add another 75-100hp easily. Nice work so far
Old Jun 30, 2014 | 04:14 AM
mkiv20vt's Avatar
mkiv20vt
This is true. I've entertained it, trust me.
I'm on the fence with which direction to take from here...Boost or NA. That ultimately decides how the build flows from this point.
Old Jul 5, 2014 | 04:46 PM
mkiv20vt's Avatar
mkiv20vt
Road trip time! Off to FL tomorrow in the Z. Wish me luck!
Old Jul 14, 2014 | 07:32 AM
mkiv20vt's Avatar
mkiv20vt
2k miles round trip and all is ALMOST well.
Z has been having issues staying cool while at low speeds/idle. Does fine 55mph+. Fans are too small for the setup, but almost the biggest the radiator will allow.
Swapped the stock core with upgraded fans and all seems well for now. Need to do more traffic/road testing, but seems to have helped the issue.
Old Jul 14, 2014 | 07:35 AM
eZg's Avatar
eZg
perhaps a vented hood may help?
good luck
Old Jul 14, 2014 | 07:43 AM
Dayhoff35's Avatar
Dayhoff35
Not the first time I have heard of cooling issues with this swap. The other one I heard about bought a vented carbon fiber hood and I think that did the trick. Also any pictures of your fueling setup?
Old Jul 14, 2014 | 09:45 AM
mkiv20vt's Avatar
mkiv20vt
Yeah, thought about that as well.
I can snap some pics for ya if you'd like.
Its a simple setup.
Fuel Tank>Braided line to Filter>Braided line to fuel rain
>Braided return from filter to tank
Old Jul 15, 2014 | 08:01 AM
Dayhoff35's Avatar
Dayhoff35
Ah, makes sense now. From before in my thread I thought you utilized the stock hard line. Makes more sense now. Thanks!
Old Jul 15, 2014 | 08:08 AM
mkiv20vt's Avatar
mkiv20vt
I'm coming up to Frederick Friday....I'll bring the Z up if you're around. I'd love to check out the progress.
Old Jul 15, 2014 | 11:13 AM
ksuberk54's Avatar
ksuberk54
Your engine still look the same? No LS intake manifold?
Old Jul 15, 2014 | 03:01 PM
mkiv20vt's Avatar
mkiv20vt
Yep. It's the stock truck intake mani
Old Jul 16, 2014 | 07:58 AM
Dayhoff35's Avatar
Dayhoff35
I should be around Friday evening, i'll PM you my number if you wanna meet up, or come by and check out the Z.
Old Aug 4, 2014 | 08:22 AM
mkiv20vt's Avatar
mkiv20vt
Decided to pull the motor this weekend and clean up a bunch of things in the engine bay.
First things first....always hated that sub-firewall. Not a whole lot of room behind the intake to run lines or harness.
Personally, I think it looks much better. Headlight harness will be tucked in the fender well to hide as much as possible. If I had more ambition, I would fill all the little holes that I'm not using, but I don't.
Next is grinding, sanding and paint.
Old Aug 4, 2014 | 01:22 PM
  #38
armt350z's Avatar
armt350z
which headers are those?
Old Aug 5, 2014 | 04:46 AM
  #39
mkiv20vt's Avatar
mkiv20vt
Fueled Racing
Old Aug 5, 2014 | 06:59 AM
  #40
armt350z's Avatar
armt350z
Any chance you could snap a picture of the clearance between the headers and the steering knuckle?
