Motordyne mrev 2 Question?
Old Oct 9, 2014 | 06:43 AM
theevesh's Avatar
theevesh
Default Motordyne mrev 2 Question?
hello, Just wondering if it is worth getting the Motordyne Mrev 2 with or without the plenum spacer at the same time ( going to be ordering online) I had the plenum spacer on my other Z and noticed a difference via butt dyno, but is it worth is to get both and have them installed at the same time since your going to be taking the upper plenum off? thanks
Old Oct 9, 2014 | 07:23 AM
theevesh's Avatar
theevesh
Nvm found out motordyne plenum spacers don't fit 05 35th anniversary SK I'm going to go with just m rev2. And i would assume a tune after this?
Old Oct 9, 2014 | 08:07 AM
theevesh's Avatar
theevesh
bump
Old Oct 9, 2014 | 08:58 AM
FOOKhonda's Avatar
FOOKhonda
Hmm... I've never heard of them not fitting... If you have the revup it would be practically no gain with just the spacer, but pairing mrev2 and a spacer will yield gains.. you dont NEED a une but if you want all the possible gains I would recommend it. But if you plan for other mods very soon I would wait and do those mods then do a tune
I have no tune yet and have every possible intake mod. I know I am running a lil lean but not majorly. I did the accelerator ecu reset so ecu has compensated a good amount but I know I am slightly lean. But I'm still beating turbo'd Honda's so can't complain
Old Oct 10, 2014 | 05:31 PM
theevesh's Avatar
theevesh
I ended up order the Mrev 2 but while i was looing at the plenum spacers it says it will not fit the 35th anniversary models. but on the motordyne website it says it go's well with their plenum spacer... which doesnt make sense any info?
Old Oct 11, 2014 | 05:57 PM
l2frankie's Avatar
l2frankie
sounds weird to me i would call and ask but there shouldnt really be a problem
Old Oct 11, 2014 | 06:39 PM
RUNWDVL's Avatar
RUNWDVL
It'll be fine.
Old Oct 11, 2014 | 09:39 PM
hotdawwgman's Avatar
hotdawwgman
It will work
Old Oct 14, 2014 | 06:13 AM
theevesh's Avatar
theevesh
alright thanks for the help
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
