Looking for a review - Exedy Stage 2 Clutch
Old 02-03-2015, 12:13 PM
pfregeolle
pfregeolle's Avatar
Default Looking for a review - Exedy Stage 2 Clutch
I've been searching all day, and have been unable to find too much info on the Exedy Stage 2 single disk clutch for the Z. Can anyone point me in the right direction, or give some input if you've used this clutch?
Thank you!
Old 04-17-2015, 11:10 AM
iire1oaded
iire1oaded's Avatar
I have this clutch. Lightweight flywheel and all - 06952FW is the package item #.
Really have had a hard time liking the clutch, it is great when mashing through gears. Never had a problem with slippage or anything. I use my 05 base as a DD and its just real bad in any slow moving environment. The chatter noise is unbearable from inside and out of the car. Feels like the bearings were not replaced or working correctly in my specific case.
10/10 clamp power, shifting abilities
1/10 chatter noise
Old 04-21-2015, 06:55 AM
pfregeolle
pfregeolle's Avatar
Thanks for the post.
I ended up going with this clutch, and I'm really enjoying it so far.
You're right, it does have tons of clamping force, which is awesome for me because I want to continue using the car for drift.
I paired the clutch with a Nismo flywheel, and I too have the chatter. Probably not as bad as yours is, since the Exedy flywheel is lighter (even though the Nismo is actually made by Exedy as well). But I can deal with it.
Anyone thinking about getting this clutch, I'd say make the jump! I'm loving it so far - Grabs real hard, but has a fairly light pedal feel. It's much easier to push in than my Carbonetic single I had prior.
08-06-2021 06:19 AM
sherm
04-11-2020 05:21 PM
EnjukuRacing
09-30-2015 06:55 AM
Quick Reply: Looking for a review - Exedy Stage 2 Clutch
