Supercharged getting a P0175 - Too Rich
Old Feb 7, 2015 | 12:52 PM
robdumoulin's Avatar
robdumoulin
Default Supercharged getting a P0175 - Too Rich
Help Guys!
My '03 Stillen Stage 3 (7 PSI) has been rock solid since new. No issues. Driven only for fun, it now it has 68K Miles and is throwing 2 P0175 codes: Left and Right bank too rich. When I start the car, it idles low and rough until I warm it up a bit. Then it runs OK. It seems lower on power but I've gotten used to driving a less-tamed muscle car and cannot be sure. Only stalled once and is manageable but not quite right.
I put in the expensive Bosch Platinum plugs about 2 years ago and am about to pull them to check how they look. K&N gets cleaned fairly regularly, but not before the P0175 codes started showing up. That should not have been the problem.
What are some diagnostic things I can do to narrow down where the issue is?
Thanks guys, you are always the best source!
Old Feb 7, 2015 | 04:30 PM
Conway_160's Avatar
Conway_160
Have you looked to see what your afr's are, Or just going off of your codes? If your running rich now you may have a boost leak, has you boost levels changed at all? You dont need expensive spark plugs nkg's will work just fine. I was spitting fuel out of my exhaust and never got that code fyi.
Old Feb 8, 2015 | 05:46 AM
robdumoulin
I am going off the codes. I do not know how to get an AFR reading, but have the following Short and Long Term Fuel Trim readings:
B1 STFT 0.0%
B1 LTFT -7.8%
B2 STFT -25%
B2 LTFT -25%
I think that shows Bank 2 is whacked but Bank 1 also shows an error. Which side is bank 2?
Old Feb 8, 2015 | 06:27 AM
Conway_160's Avatar
Conway_160
I THINK B1 is cylinders 1,3,5 and B2 is 2,4,6.
Are you close to a dyno or a tuner?
Old Feb 8, 2015 | 08:49 AM
robdumoulin
The two dyno shops I go to specializes in Fords or Chevys.
Read another code. Fuel System 1 OL Fault.
Fuel System 2 CL
ECT 172 Degrees F.
Calc Load 49.0%
What does an Open Loop fault mean?
What is the difference between Fuel System 1 and 2?
Anything else relevant?
Old Feb 8, 2015 | 09:12 AM
NissanZcrazy's Avatar
NissanZcrazy
Fuel System 2 CL
ECT 172 Degrees F.
Calc Load 49.0%
Is ECT 172 degrees F reading when your engine is warm?,does it get hotter than that? Your engine may not be going into closed loop due to low temp readings
Also if the ect reads a low temperature it will richen up the afr to lite up the cat converters,Whether you have cats or not...
I know my ect reads around 190F-210F roughly.
So you may either have a faulty ect sensor or a thermstat problem.
Last edited by NissanZcrazy; Feb 8, 2015 at 09:19 AM. Reason: Spelling,unsure of answer
Old Feb 8, 2015 | 10:03 AM
robdumoulin
The ETC reading I believe is written at the time of the fault. To test that, I warmed the car up to normal temps, stopped it, then cleared the codes. When I would clear the codes with the car cold, the Check Engine light would come on within minutes. Resetting the codes with the car warm did not trip a Check Engine yet and therefore I have no entry for the ETC. I'll have to wait until it cools down to see if it trips quicklly when cold.
Another piece of the puzzle:
My on board computer says I am getting 42 MPG when the check engine light is on. Woo hoo! It returned back to normal when I reset it hot and drove it.
350Z_Al
Oct 29, 2020 07:44 PM
seagrasser
Oct 11, 2015 03:27 PM
Calinismo350z
Sep 14, 2015 04:04 PM
