Engine overheat.tried almost everything
Old Feb 17, 2015 | 12:54 PM
dkgaby's Avatar
dkgaby
Default Engine overheat.tried almost everything
Hi. I own a 2004 Nissan 350z that overheats when going uphil in a hot day. After cleaning the radiator, flushing the system, and making sure no air pockets remained in the heater line, the car still overheats in the aforementioned conditions. The water flows out when the radiator cap is off and the engine running. I ran a radiator pressure test and it held about 30Psi. Then ran a compression test which gave 200Psi for all cilinders. All this to make sure the head gaskets are ok. What could be the problem here?
Old Feb 17, 2015 | 01:48 PM
FOOKhonda's Avatar
FOOKhonda
Even though the radiators full put some coolant in the reservoir that fixed my problem.
Also could be thermostat or water pump.
Old Feb 17, 2015 | 01:49 PM
eZg's Avatar
eZg
9 out of 10 times it's air in the system. They are crazy tough to bleed.
Old Feb 17, 2015 | 01:55 PM
FOOKhonda's Avatar
FOOKhonda
This is also very likely. I bled mine for awhile even though I never touched anything for awhile there and the bleeding and putting water in the reservoir did the trick.
Old Feb 17, 2015 | 07:24 PM
Turnstien's Avatar
Turnstien
Not sure how these cars work dealer flushed my Z never had a problem. But I had a older work truck over heat on me ended up being the thermostat was stuck and this was after I flushed it. Good luck
Old Feb 17, 2015 | 08:58 PM
i8acobra's Avatar
i8acobra
Drive the car until it starts to get hot then feel the lower radiator hose. If it's noticeably cooler than the upper hose, you need a T-stat. Common for them to fail closed on a VQ35.
Old Feb 18, 2015 | 06:50 PM
bealljk's Avatar
bealljk
this is smart...
I had heating issues a little while back and I removed my thermostat element to cycle coolant 100% and also bled/vacuumed out air (in a mad scientist sort of way) before my issues cleared up.
liqalu04
Jan 2, 2022 12:58 PM
3vilbunny
Jul 18, 2017 05:10 PM
Fixxxercask
Nov 9, 2015 11:10 AM
