350z Spark Plug Tube Seals
Old Apr 30, 2015 | 04:52 PM
Nismobarrios's Avatar
Nismobarrios
Arrow 350z Spark Plug Tube Seals
Hey guys I am new to the forums and have a few questions. I am going to change my valve cover gasket and also want to change the spark plug tube seals. I have the gasket already but for the tube seals I was wondering if anyone has used the Fel-Pro ES72481 Seals and if they fit? IT\t says theyre compatible with my 2004 350z but want to make sure if anyone has used them on their vq engine! If anyone could help me that would be great thanks!
Old Apr 30, 2015 | 05:10 PM
koren's Avatar
koren
Quick answer: No, it will not fit.
As far as I'm concerned, you got 3 options:
1. New OEM valve covers
http://www.z1motorsports.com/350_g35...oducts_id=7167
2. R&D valve seals kit
https://my350z.com/forum/engine/6030...r-kit-diy.html
(you can find DIY here on the site)
3. Altima valve covers (require some mods).
http://g35driver.com/forums/faq-diy/...lug-tubes.html
If it was up me, I would go with the option #1, since I don't feel comfortable with modifying and fitting valve covers from the other model and also I had bad experience with R&D kit:
This is just one cylinder, didn't check the rest.
Old Apr 30, 2015 | 05:21 PM
Nismobarrios
Thanks Koren I really appreciate the help! I might just end up going the the R&D kit and see how it goes from there! what kind of problems did you have with it?
Old May 1, 2015 | 02:17 AM
RobPhoboS's Avatar
RobPhoboS
I installed the R&D kit - all good, just take your time, do it PROPERLY and use plenty of high quality RTV silicone. I also recommend doing an oil change afterwards just in case any little bits of plastic or rtv drop into the engine.
Old May 1, 2015 | 08:51 PM
koren's Avatar
koren
RobPhobos, I did it in my friend's fully equipped garage, it took me 3 days - was doing everything very patiently and properly was waiting for the silicone to dry before starting the engine. Everything was done according to their youtube video.
May be it was me that did something wrong, but I'm not a newbie in this, so it is either too hard to do correctly or does not work properly. Either way is not good for your car, so my recommendation - get a new valve covers.
Old May 1, 2015 | 10:36 PM
RobPhoboS's Avatar
RobPhoboS
But obviously something was wrong if it works for plenty of other people.
Dr.Paulyy
Jul 29, 2019 07:45 AM
allmycarsdie
May 13, 2016 04:38 PM
B Esquire
Sep 24, 2015 07:52 AM
RyansZ33
Sep 15, 2015 05:54 AM
juang20
Intake
Sep 7, 2015 05:37 PM
