Oil Filter + Mocal Sandwich Adapter ???
Old Jul 17, 2015 | 09:12 PM
zyou8er's Avatar
zyou8er
Default Oil Filter + Mocal Sandwich Adapter ???
Hi guys, i ordered a Mocal Thermostatic plate for the oil cooler kit im putting together, My question is which oil filter you guys run with this adapter. Currently i run the Purolator Pure1, any info would help. Thanks!
Old Jul 18, 2015 | 05:48 PM
guitman32's Avatar
guitman32
The threads are the same as OEM (if you order the correct part #) so use any oil filter you want.
Old Jul 18, 2015 | 06:31 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
^i think he is more worried about the stackup and length of the current oil filter
I have a mocal sandwich plate but I deleted the stock oil cooler so my stackup did not increase. I used a longer filter than the stock size. You should be fine with stock length.
Old Jul 18, 2015 | 06:41 PM
guitman32's Avatar
guitman32
Oh, well in that case I still have my oem exchanger, mocal thermo plate, and run a standard oem size filter without issues.
Old Jul 18, 2015 | 10:05 PM
zyou8er's Avatar
zyou8er
Sweet, Thanks guys! BTW., I used this site to order all the parts. Went with TruCool 36 row cooler, all AN fittings with socketless hose, and thermostatic adapter, all for under $260 I went with the biggest cooler, as i will be using the car mainly for track, and i live in a hot part of CA, i think the 36 row takes almost an extra full quart of oil.
http://www.racerpartswholesale.com/
lapham3
Oct 7, 2022 03:15 PM
