No engine electronics
Old Oct 11, 2015 | 03:57 PM
Shane Vasquez's Avatar
Shane Vasquez
Default No engine electronics
So I am hosting a drift event next weekend, so i was out at the track today working on the layout. Well i turned the car off, then went to turn it back on and it will not start. My throttle body is not working, and the fuel pump is not turning on. i am thinking maybe ECU because when I first put the key in before starting there is no check engine light on. Any Ideas? i have had the issue before and eventually it just started working again.
It is an 04 G35.
Old Oct 11, 2015 | 05:59 PM
bealljk's Avatar
bealljk
did. you. check. your. fuses?
Old Oct 11, 2015 | 08:18 PM
Shane Vasquez
Fuses where good, but a friend brought up a really good point a bit ago that I had been thinking about. Might be the IPDM. It got wet a lot last year, (had no hood on) and a bunch of the connections inside are corroded, even had a bunch of relays go out. I had this no start issue before, but after I wrapped it in a plastic bag I have not had the issue, wonder if it finally died today. Going to do some serious wire checking on it, see if it is sending power out where it should be. I have been wanting to replace it anyways, so might as well and see if it fix;s the issue.
Doober
Dec 15, 2015 05:54 AM
4ngryToasters
Oct 14, 2015 12:38 PM
Hornlesscow
Oct 10, 2015 04:43 PM
DeeCryme
Oct 7, 2015 07:47 PM
zacav8r
Oct 6, 2015 06:23 PM
