Just seafoamed my Z, smoke came out of only left exhaust
Old Nov 2, 2015 | 03:54 PM
gearhead350's Avatar
gearhead350
Default Just seafoamed my Z, smoke came out of only left exhaust
I seafoamed my 03 350z and smoke only came out of the left exhaust pipe, nothing from the right one...it has injen SES exhaust true dual, anyone know why this could happen?
Old Nov 2, 2015 | 04:13 PM
jhc's Avatar
jhc
General & Tech Moderator
I'm not a Sea Foam fan, but there should be some good advice coming shortly.
Old Nov 2, 2015 | 04:54 PM
HRMoneyPit's Avatar
HRMoneyPit
That's odd. Smoked out both mine with my HR
Old Nov 2, 2015 | 05:00 PM
gearhead350
I know I don't get it, all the videos iv seen smoke is coming out of both, idk if it has something to do with the true dual exhaust system or what, but this is the 2nd time iv seafoamed and the first time smoke came out of both but mostly came out the left but this time there's nothing out of the right
Old Nov 2, 2015 | 05:01 PM
SmoothZ's Avatar
SmoothZ
Senior Super Moderator
My only question is How did you use that Seafoam?
Old Nov 2, 2015 | 05:02 PM
gearhead350
I evenly distributed the seafoam can and put it in my oil, gas tank, and the brake booster hose
Old Nov 2, 2015 | 05:09 PM
jhc's Avatar
jhc
But to your point. I'm not as concerned about the exhaust pipes being equal. Did you notice any improvement in driveability after putting this product in your car?
Money well spent?
Old Nov 2, 2015 | 05:14 PM
gearhead350
Money well spent?
Yes its a lot smoother, I just don't understand why all the smoke came out of the left and literally nothing out of the right
Old Nov 3, 2015 | 04:53 AM
SmoothZ's Avatar
SmoothZ
Let me get this straight. You put seafoam in your oil and brake booster? AFAIK, you should only mix it with a full tank of gas.
Old Nov 3, 2015 | 05:09 AM
Stolly08's Avatar
Stolly08
I mixed a half can with a half tank and did the rest from a vacuum hose once it worked a little bit. But in the oil??? That sounds like a horrible idea!!! Why would u do that?
You know it isn't a 2 stroke right???
Our oil doesn't mix with our gas it stays separated.
But only coming from one means only one side of your V engine has gunk in it... Pretty easy concept... The left had some gunk and the right side didn't.
But I would do an oil change immediately and get that ish out of there before you ruin your engine!
Old Nov 3, 2015 | 05:19 AM
jhc's Avatar
jhc
They sell it as an all in one solution, with 1/3 going into crankcase, drive 15 minutes and then change the oil. Some people swear by it, others think it's a gimmick.
I always go by what's inside the MSDS.
Old Nov 3, 2015 | 05:25 AM
Stolly08's Avatar
Stolly08
Ya true as long as he knows to change his oil then lol...
My buddy and me did a lot of research on oil back when we did it and came to the conclusion its more or less meant for older engines that have those issues... Our newer stuff doesn't necessarily have those issues... At least the HR and up... His DE back then smoked a good bit and as I said mine didn't much and he has a 09 370 now and hasn't tried it yet bc with our custom tunes we run pretty clean.
Old Nov 3, 2015 | 05:44 AM
jhc's Avatar
jhc
Just looked at MSDS and remembered why I'll never use it.
Isopropanol (alcohol) < 25%
Aromatic hydrocarbon solvent < 90%, but they refuse to list exactly which solvents, claiming proprietary secrets.
I'll go with Techron and Berryman B12.
Old Nov 6, 2015 | 02:39 AM
thekyledeg's Avatar
thekyledeg
It probably only came out of one pipe because you used the vaccum brake booster hose to induce it to the intake. The brake booster port is located on the left hand side of the upper intake. So my guess is you only fed those three cylinders with seafoam, thats why only one pipe was smoking.
Old Nov 6, 2015 | 09:42 AM
gearhead350
Yeah that makes sense but this is the 2nd time iv seafoamed and the first time it came out of both
Old Nov 6, 2015 | 10:00 AM
MicVelo's Avatar
350Z/370Z Tech Moderator
FWIW, I don't EVER use additives other than that which is recommended by the manufacturer - Techron being one of those.
But that's not to say that SeaFoam is bad as there are many test reports and lots of satisfied users.
Personally though, I think a lot of it is hocus pocus (read: "marketing".... and as a career sales person, I am naturally skeptical about said "marketing". Laff.... If you don't get that, you can ask me about that cynicism and anti-marketing sentiment in The Lounge)
The word "placebo" comes to mind.... But who am I to say, not ever having used the stuff nor ever finding a reason to.
Mic
Diode Dynamics
Body Exterior
117
May 27, 2021 11:13 AM
gotama
Apr 12, 2016 08:10 AM
zacav8r
Nov 23, 2015 12:37 PM
CWDings
Nov 2, 2015 05:26 AM
AlphaZ33
Oct 28, 2015 06:14 AM
