Cam bolt won't budge WTF!!!
Old Nov 21, 2015 | 12:26 PM
timmays350's Avatar
timmays350
Default Cam bolt won't budge WTF!!!
Rebuilding my VQ got everything out 90% of the **** off and hung up on the exhaust cam bolts. Intakes came off fine but the exhausts won't budge. Anyone else had this problem or have any input??
Old Nov 21, 2015 | 12:43 PM
Conway_160's Avatar
Conway_160
Big *** impact!
Old Nov 21, 2015 | 05:29 PM
dkmura's Avatar
dkmura
General & DIY Moderator
Have you soaked the exhaust bolts with breakaway lube overnight?
Old Nov 21, 2015 | 10:39 PM
350z-Helsinki's Avatar
350z-Helsinki
Those were on tight in my engine too! Breaker bar and a wrench inside a pipe should do it. You probably need a friend to help out. Are you sure it's a good idea to use impact here?
Old Nov 22, 2015 | 06:03 AM
Conway_160's Avatar
Conway_160
If you have some one with a big *** Crescent Wrench you should be fine to use a Impact.
Old Nov 22, 2015 | 12:12 PM
35reilly's Avatar
35reilly
What are you going to be referring to? Manual or pdf files for all the correct info for disassemble and assembly? I'm getting ready to pull my timing cover off and take heads off and to tell u the truth I'm a little freaked out about it. I just want to make sure I not only follow the process correctly but I have all the info I need to complete the job.
Dec 2, 2015 09:20 PM
bazguitarman
South East
Nov 26, 2015 09:09 PM
aXxICExXa
Nov 23, 2015 01:32 PM
Bak3rme
Nov 20, 2015 07:31 AM
