Car died on the road
Old Dec 31, 2015 | 05:16 AM
allmycarsdie's Avatar
allmycarsdie
Default Car died on the road
My 350z just shut off the other night as I was driving. It started up about 5 minutes later first try, but the check engine light was on. I haven't had to go anywhere since and I'm a little worried to just in cas further use would mess the car up more. Ive found multiple things online that could be the problem, one of which is highly suspect. It seems that the crankshaft positioning sensor can cause this. I just installed a new clutch and flywheel about three weeks ago and noticed that my CPS was absolutely covered in clutch dust, and my clutch, and flywheel was in possibly the worst condition I have ever seen any of these components in. I'm sort of hoping my problem is just an overheated, overly dirty, worn out CPS. I have only put about 3000 miles on my '03, and it was my first manual car so I had no idea that my clutch was worn due to pedal feel until it started slipping pretty badly. I had to drive it slipping for about 450 miles due to money and time issues. The new clutch and flywheel have been running wonderfully for the past three weeks with the old CPS. Does anyone know if this is the problem or have any experience with a bad CPS?
Old Dec 31, 2015 | 05:26 AM
travlee's Avatar
travlee
Master
you cursed yourself with your username dude!
go get the codes read and then you will know exactly what the problem is
Old Dec 31, 2015 | 06:06 AM
dboyzalter's Avatar
dboyzalter
6 inch cawk is my fave!
Old Dec 31, 2015 | 07:14 AM
Highway Riding's Avatar
Highway Riding
check the battery connections. I had my car die when i would come to a stop cause of loose connections.
Old Dec 31, 2015 | 08:01 AM
Z33Garage's Avatar
Z33Garage
Both the crank and camshaft position sensors can cause this, and in the Zs these sensors are notorious for failing.
My money would be on the sensors failing, a quick OBD2 check would confirm this issue.
Luckly the sensors are easy to replace, but not what I would call cheap.
Old Jan 1, 2016 | 04:31 PM
jv350z's Avatar
jv350z
yes, it could be a $10 sensor. just pull the codes and stop guessing
ajcool2
Mid-Atlantic Marketplace
Jan 29, 2016 12:50 PM
new350zguy
Jan 15, 2016 04:06 PM
Smokey Bear
Jan 1, 2016 07:04 PM
Shmoke
Dec 31, 2015 05:40 AM
fernandotb13
Southern California
Dec 30, 2015 10:50 PM
