Flooring first gear leads to clutch engagement problems PLEASE HELP
Old Mar 1, 2016 | 07:26 AM
travlee's Avatar
travlee
Master
You replaced the master also, correct? The wilwood one? If so you may need to adjust the rod. Call Joe at z speed and he can walk you through it
Old Mar 1, 2016 | 07:28 AM
travlee's Avatar
travlee
Master
Also.... how many times did you come close to emptying the reservoir bleeding it
Old Mar 1, 2016 | 07:30 AM
George's350z's Avatar
George's350z
Like 5 or 6 times
Old Mar 1, 2016 | 11:16 AM
George's350z
I called Joe at zspeed and he said since the clutch goes all the way up and its engaging properly he thinks it's the clutch or pressure plate thats broken. He stated that if the stick shift goes into gear when the car is off and doesn't when it's on, most likely indicates broken or worpped pressure plate. So I'm going to drop the transmission again today and take a look at the pressure plate before I fork out $500 again.
Old Mar 1, 2016 | 11:17 AM
travlee's Avatar
travlee
Master
Old Mar 1, 2016 | 11:22 AM
George's350z
It's not bad at all dropping the transmission on these cars. I just want the piece of mind that it's not a transmission issue.
Old Mar 1, 2016 | 11:25 AM
travlee's Avatar
travlee
Master
have you changed the trans fluid?
Old Mar 1, 2016 | 11:30 AM
George's350z
Not in the year I have owned the car, no.
Old Mar 1, 2016 | 11:35 AM
travlee's Avatar
travlee
Master
might want to do that, just for peace of mind
Old Mar 1, 2016 | 05:30 PM
George's350z
So I dropped the transmission once again (which I think I did in records time) and found this!
Old Mar 2, 2016 | 03:08 AM
travlee's Avatar
travlee
Master
what in the hell....
Old Mar 9, 2016 | 09:03 PM
George's350z
Posting an update for anybody that comes across this thread with the same problem. Finished replacing the clutch to southbend stage 2 street, replaced the pressure plate on the Jwt Flywheel, and changed transmission oil to redline gear oil. Went for a small drive and it engages properly and the noise is reduced by 95%.
Old Mar 9, 2016 | 09:04 PM
George's350z
Now its time for break-in till about 350 miles before I can take it up to higher rpms.
NYKnick1015
Engine Swaps
Nov 20, 2020 06:39 PM
RichV
Jun 1, 2017 05:07 PM
usafmarker
Mar 17, 2016 10:12 AM
ipodhustle
Feb 26, 2016 11:21 AM
Reckless350z93
Feb 22, 2016 11:24 AM
