ECM Relay Replacement (urgent)
Old Apr 16, 2016 | 02:54 PM
2one8's Avatar
2one8
Default ECM Relay Replacement (urgent)
So I suspect my ECM relay went bad. Rebuilt the motor over the winter, fired her up and it idled fine, did a few restarts while checking items and now it wont start. No power to the coils at all. Checked the ECM fuse and thats fine, only other item in the way is the relay. I have done some digging and Nissan says you have to replace the entire IDPM, but I have seen some talk about guys swapping just the relay from other vehicle models. Does anyone have experience with this? I have to get this running by Thursday to make my tune date, otherwise I cant get tuned until mid July.
Old Apr 17, 2016 | 02:10 PM
BakaN20's Avatar
BakaN20
Try the IPDM auto active test
http://www.titantalk.com/forums/tita...tive-test.html
Another thing you can try is take the relay in the ipdm for the wipers or something similar to the ECM relay and just switch them and test the wipers to see if it is actually a bad relay.
I had the same issues where my car would not start, tried replacing the ipdm and such, found out it was a fried ECM.
Old Apr 18, 2016 | 04:42 AM
2one8's Avatar
2one8
I swapped it with the A/C relay, same part number, still nothing. So then I got out the FSM and stated testing from the ECM forward. By the time I got to the coils I had power again, so I'm guessing it was a bad ECM connection. Everything works now, fires up and idles.
kennyy
Apr 24, 2016 03:10 AM
CUL8ER
Engine Swaps
17
Apr 18, 2016 03:38 AM
heyyouduh
Apr 15, 2016 07:00 PM
