Oil Pressure
Old May 20, 2016 | 07:03 AM
daxman's Avatar
daxman
Default Oil Pressure
I have a 2006 Z with 101,000 miles auto. After the car has been sitting over night or all day the oil pressure gauge reads high when I first start out. After some time it goes down a little but still reads 90+. That seems high to me or am I concerned over nothing. The car does not leak or use any oil.
Old May 20, 2016 | 07:42 AM
rancor's Avatar
rancor
Sounds like you have a dead sending unit. The oil pressure should be variable something like 15 psi min at idle and >45psi at 2000rpm when fully warmed up.
Old May 20, 2016 | 08:17 AM
daxman's Avatar
daxman
Thanks, how hard is it to replace? Can a shade tree mechanic like myself do it or do I need a pro?
Old May 20, 2016 | 11:21 AM
dcains's Avatar
dcains
It's easy to do, but it's also very easy to crack the upper oil pan the sender threads into. Plenty of treads here where that's happened.
Old May 20, 2016 | 12:53 PM
rancor's Avatar
rancor
It should be easy but there have been some threads recently of cracking the upper oil pan. Also thread sealer is needed according to the FSM.
On my 07 the sending unit does not seat into the block it still has threads exposed, probably about half of them. I have wondered if people tighten them too much, it's only spec'd to 13 ft-lb max.
Old May 20, 2016 | 03:32 PM
dcains's Avatar
dcains
That's because it's a tapered pipe thread.
Old Jun 15, 2016 | 02:58 AM
daxman's Avatar
daxman
Default Thanks
I replaced the part and that resolved the issue. Thanks to everyone who took the time to comment.
ISC Suspension
Jan 26, 2017 08:05 AM
jdm-v35
May 5, 2016 06:54 PM
bean_vq35de
May 1, 2016 05:50 PM
Double_Take
Apr 27, 2016 08:34 AM
